Question about Panasonic CT-36HL43 36" TV
I have a CT-27D30B that has started going off then back on by it self. No pattern. It used to go off for shot periods of time but has increased to 5 or so minutes. What part should I replace? Is the entire power supply shot?
  • 130 Answers
Hi
no you might have a solder problem or cold joint probably in HV section
Posted on Oct 02, 2010
  • Panasonic Master
  • 506 Answers
If resoldering potential dry joints doesn't cure it, then it's possible one or more components are leaky, such as diodes and electrolytic capacitors, then progress to more elaborate parts, like transistors and ICs - particularly the horizontal output transistor (don't forget to check the tuning capacitors in its collector circuit - replace those along with the transistor if required).
Posted on Mar 09, 2011
How to increase a knitting pattern Gingersnap
Usually increasing stitches is accomplished by knitting (or purling) twice in the same stitch.
How to Increase and Decrease Knitting Stitches For Dummies
Decreasing is accomplished by knitting (or purling) two stitches together.
Jul 14, 2016 | Sewing Machines
Ct 2579 When I main supply made ON & start to switch on by remot control,it does not start but after few minutes then after I again try, then it start to display.so Iassume that some one capacitor...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 10, 2017 | Akai Televison & Video
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
I have exactly the same problem as dcalva (dan) as I will quote below. -badearings I have the Motorola MOTOROKR S9-HD and I use it with my iPhone 4. Recently when I started using it, the sound...
There is the two way to unlock your pattern
  1. you have to chosen recovery pattern if you set up before
  2. and you have to go to the local store who repair the phone then can help you to remove the pattern by updating your software
May 18, 2017 | Motorola Mobility MOTOROKR Bluetooth...
Shutter will not close back to starting position with each shot
cablechick25,
do you mean the shutter doesn't close all the way? put select on B , gently push shutter to the left to fully close the shutter. charge shutter and fire it a few times, it should free itself after a few shots.
any mechanical device needs a periodic clean, lube & adjust, ( CLA ), after not being used for 5 years your X350 just needs that. take it or send to a camera repair shop for an estimate first. there are no new parts available for this model minolta.
Jan 23, 2009 | Minolta X-370S 35mm SLR Camera
Self-cleaning frigidare stove
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Panasonic CT-27D30B
Put a voltmeter on the vertical I.C .
pin 1 should be 12Vdc
pin 2 should be 24Vdc
from those two inputs, it should be generating at least 50V on pin 13.
If those are not present, trace the power back to its source in the flyback circuit, where a resistor or diode has blown.
If present, check its output on pin 12 and if there, trace through the vertical output circuit.
If not, it may not be getting a trigger pulse from the main video chip.
Hope Ya Fix It!
Jan 18, 2008 | Panasonic CT-32SL14 32" TV
Dimage Z3 self-timer
It is in the Drive mode, the options are single shot, continuous, bracket, and self timer. It is not very clear in the manual but it is on the 1st menu page, page 46. Navigate using the arrow button. The default is single shot. When you set the camera to self timer, after taking the shot, it will return to the previous mode, ie. single shot or continuous. If you always use the self timer, you can reprogram the flash mode button to set the drive mode without going to the menu, page 65 of the manual. If you do not have a manual, you can download here : http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/index.html
Apr 23, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Panasonic CT-36HL43 36" TV Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
