Question about Toshiba 61H71 61" Rear Projection Television
Toshiba 61H71 tv will not come on. I have checked the only fuse that I could find and it is good. Are there any other fuses that I can check? If so exactly where are they located? I have read the other threads on this forum and they seem fairly vague. Is there a circuit & Diagram for this unit? We checked under the main cicuit board and have found no other fuses. Please advise. Thanks for all of your help.
  • 130 Answers
Hi
yes there about 5 other more but they are very
small and light green ranging from 2 to 4 amps
on power deflection board
Posted on Oct 02, 2010
Convergence IC of panasonic lcd
Hello, the i.c.'s are a STK-392-110E, there are also small Pico fuses that open up when the i.c.'s short. if you look on-line there are kits you can buy to replace the defective parts. oh and by the way your set is a projection set not an lcd type.tks
Nov 07, 2013 | Toshiba 61H71 61" Rear Projection...
My toshiba 61h71 has a reddish tint to it. Turned it off one night and it looked fine, next morning it got this reddish tint. Tried resetting the convergence but that didn't change the situation at all....
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
Dec 30, 2009 | Toshiba 61H71 61" Rear Projection...
I have a Toshiba 61H71 that keeps blowing F850. It was just sitting there the first time it did it. I didn't have a replacement fuse so I temporarly replaced it with a 3A glass barrel type fuse. This...
Resolder jumpers on signal PCB..May be near convergence IC circuit..on 50" model they are 050 & 010. You may have solder cracks..I repaired a 50" toshiba..Let me know if this fixes
Apr 15, 2009 | Toshiba 61H71 61" Rear Projection...
Toshiba model 61h71 red light comes on /no picture or sound
We had the same problem, open the panel on the back of the tv, the board on the left, not the one with the convergence chips. Inside the tv u will see a piece of paper with the fuse info. The board on the left unscrew it and flip it away from you, the fuses to test are at the bottom, on the circuit board it will say 125volt 5 amp, and the number starts with an f. they are small and rectangular and black. Check all but the 3 at the bottom are usually the culprits Hope this helps u
Jan 14, 2009 | Toshiba 61H71 61" Rear Projection...
The red power on light just blinks. Tried leaving it unplugged. Still didnt work
Ours was doing the same thing, we changed 3 little black fuses in it and it works. I do believe they are 5 amp but not positive, we found them through a tester. When I have the exact answer for u I will email u again sorry u have had no response till now probably does you no good now..It's been awhile since they were changed.
Nov 01, 2008 | Toshiba 61H71 61" Rear Projection...
Toshiba 61' cinema series rear projector
check for loose connections and or bad convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
good luck
please mark the post with a fixya!
Feb 07, 2008 | Toshiba 61H71 61" Rear Projection...
Red Shadow on Picture
convergence ic bad
Jan 14, 2008 | Toshiba 61H71 61" Rear Projection...
Toshiba 61h71 rear projection red pincushion
convergence ic bad
Jan 10, 2008 | Toshiba 61H71 61" Rear Projection...
Blinking power light
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Nov 18, 2006 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
