Question about Broderbund American Greetings Creatacard Platinum 8 for PC
The discs are not numbered which do i load first and second
    Scholar:
  • 179 Answers
Save both the disc at some place and use any one first..
if it is properly installed then it would have been the first..
if in case it would be the second one, then it would ask for the first one.
Posted on Oct 02, 2010
CD Changer will not load disc. Cycles through all 6 discs then shows code 2. The unit is not damaged and disc holder loads as normal. tried a light pressure and a harder pressure when loading, result is...
Try the following
Step 1. You need a kenwood remote that has aphone style keypad(there are many of them they have numbers and letters like a phone pad)
Step2. Turn your radio on.... it will say ENTER CODE---- and look like this CODE----
Step3. Press and hold the DISP button and the volume up button at the same time for about 4 to 5 seconds, if you did this right you will be confirmed with a beep and the screen will change from CODE---- to CODE.
Step4. Your halfway there once you get to this far... now all you have to do is enter KCAR with the remote like your texting on a cellphone
Step5. To do this press the number 5 button, you will notice that a J will appear on the screen so just press it again and aK will appear to enter the K press the track forward button >>, then press the 2 for C and so on and so on til you spell KCAR...
The 6th and final step... press the track forward button once more to enter the code and there you have it
let me know if this does or doesn't work
May 08, 2008 | Audio Players & Recorders
Unable to get DVDs plaer to work on Luxor 22 inch combi
There are two reasons for this fault. The fist one is with disc loading problem. If the disc do not load properly into the drive mechanism, or if the disc does not spins inside it. The second one is with it laser pickup unit. the fist one said above is a mechanical fault, and the second is component failure. To repair both of them, you have to take out the DVD loading mechanism out from the player. it will be best to contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 13, 2014 | Luxor Televison & Video
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
Hello
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Unlock LG DVD
The following hack worked for my player. It works for most LG and Aiwa players too. To hack the player try this:
  • Power on player with no disc inserted and wait for "No Disc" message on screen
  • (using the remote) Press PAUSE
  • Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
  • Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
  • Press PAUSE
  • Power off the player for a few seconds..power back up and insert your DVD disc
Jan 08, 2008 | LG Televison & Video
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
22 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
