Question about Sony Handycam DCR-HC24E Mini DV Digital Camcorder
Cassette won't close
All of a sudden (I blame my 2 year old!) the cassette part won't close. I can insert a tape but the tape won't click into the metal casing part that says "do not push". The camera, when turned on, reads "re-attach the power source". Any way I can fix this? Or take it somewhere to be fixed? We use the camera all the time and love it!
Thanks,
jessie
Did this problem ever get solved? We are currently having EXACTLY the same problem with our dcr-hc24e!
Posted on Apr 14, 2011
  • 10,594 Answers
Dear Jessie,
Have you deattached battery of camcorder and reattached it? Please do it. Hope problem will be fixed. And if not, you should go to nearest Sony service shop because it seems hardware problem.
Posted on May 26, 2008
Sony HDV Z1U C:31:23 will not load tape cartridge
Tape may be jammed. Try to move tape with pencil eraser
like with the old cassettes.
Mar 14, 2013 | Sony Used HVR-Z1U 1/3" 3-CCD HDV Camcorder
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Upon inserting the cassette tape into the GR-DV310, the motor whirs like it is going to close; but then the cassette carrier opens to the extract cassette position. The system does not close and does not...
This is most likely a problem with one of the motor sensors and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 06, 2011 | JVC GR-DVL310 Mini DV Digital Camcorder
Tape is torn and I need to get it out of the cassette housing, splice the tape, then place in a new housing. Where can I get a repair kit??
Cat. No. 44-626 used to be available at Radio Shack but no more.
http://www.tracertek.com/new-cassette-tape-shells
This might work..
http://www.gearslutz.com/board/geekslutz-forum/31114-cassette-repair-kit.html
"Splice the broken end to the take up reel of a newly bought cassette that you can open.
open the new cassette,
trash the interior
If you can't move the old reels to the new mechanism:
tape one side of the broken cassette's tape to the new take up reel
close the new cassette (do not open or break the old cassette if it's not already done)
insert a pencil into the gizmo on the take up reel on the new cassette,
reel up the old cassettes tape into the new cassette
re open the new cassette
splice the other end to the new cassette's gizmo
record the contents to digital"
Feb 05, 2011 | Audio Players & Recorders
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Hitachi Camcorder VM E220A - After load cassette "TAPE" error
There is a mode switch within the deck assembly that is probably dirty but not cleanable. I haven't repaired one of those for some years and am sure spares are no longer available for it. The 58 is V8 format and should be OK but may show similar symptoms due to age, in the future.
May 24, 2017 | Hitachi i.mega HDC-401 Digital Camera
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sony Handycam DCR-HC24E Mini DV Digital Camcorder Logo
271 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
