Question about HP Wireless Optical Mouse
HP wireless mouse is not working. Its showing up in the device manager
    Scholar:
  • 179 Answers
Install proper drivers for your wireless mouse by the cd which would have been provided to you
Posted on Oct 02, 2010
3 Suggested Answers
SOURCE: wireless mouse not working
We had the same problem and just found this solution, we don't know how long it will work for!
http://www.eggheadcafe.com/software/aspnet/29649087/usb-mouse-wireless-proble.aspx
hey - i think i actually found the answer.
there is a reset button on the bottom of the mouse.
and there is a reset button on the receiver that plugs into the USB. click them both and vuualla! - it works again....
we'll see how long this lasts.
(most blogs tell users to just exchange the set, it's poorly designed)
good luck -
Posted on Jul 12, 2008
SOURCE: my HID usb mouse is not working
This a problem with windows. An error in the registry isresponsible however your standard scanners dont help much. Check the mouse on another pc if it worksyou have several choices. 1. Reinstall/Repair windows on the machine the error has occured on. 2. Attempt to locate what hasgone wrong in the registry many advise t delete the mouse info from the registry and reinstall the generic drivers. I saw this problem CAUSED by a windows update just after SP3. please guys dont tell people there hardware needs replacing without troubleshooting. The site is called fixya.
Posted on Mar 28, 2010
I can be typing and either a letter or number (not anywhere near the location I am typing) will appear in the word. Sometimes I will be typing and all of a sudden the typing shows up somewhere else on...
IF you are using something that has a touch pad on it, chances are that you are hitting the pad while typing and the cursor jumps to the wrong spot and lays down letters. I have also see this happen with shortcuts too. Try covering the touchpad with cardboard and typing.
Jun 09, 2017 | HP 386209-001 Keyboard
MY HP PAVILLION'S PORTS DON'T WORK, INTERNAL WIRELESS DOESN'T WORK AT ALL
Most of the laptops those are the common issues Wireless are not working, what i suggest is try to renistall the Driver for the wireless card then check it in the Device Manager, if it doesn't show in Device Manager the wireless card could be faulty.
How to check Device manager.
Start->Control Panel->Device Manager
Inside Device Manager look for Network Adapter and check if your wireless card is detected.
Apr 04, 2011 | HP Pavilion dv6000 Motherboard
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
Mar 15, 2011 | HP Wireless Optical Mouse
I have a samsung np-nf110/nf210/nf310 , os is windows 7 starter. i wanted to use my HP wireless optical mobile mouse but it doesn't seem to work or i dont think it connected. batteries are brand new and...
we dont do Samsung here, its HP
but HP mouse with no model stated, is impossible to be accentuate.
its a wireless mouse right, you left only small hint.
battery powered wireless mouse ,.by HP
windows 7
wireless mouse, HP and Samsung.
that takes 2 working drivers to make that work. both HP
the USB side and the mouse side.
HP does not support this on non HP computers so windows 7 is the only hope, MICROSOFT PLUG AN PLAY
you must be connected to the internet or its all just a wasted of time,
do so.
then plug both those things in.
the PC goes Dingdog sound telling you its found a new USB device.called wireless mouse HP, (no model stated)
then tries to find a driver on the web, MS servers for that.
if it can find one, then good luck, doing that. as the HP drivers will not like your PC
as here, if this is possible at all.
https://h30434.www3.hp.com/
Jul 05, 2017 | HP Wireless Optical Mouse
My keyboard will not work but my mouse will
add the device manually using a wired keyboard. go to device manager then add a device. follow the prompts. then if it shows you a password, type that using your wireless KB to connect it.
Mar 30, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I just dropped my mouse by accident and it doesn't work now. How do I fix this?
open up the door to make sure the batteries are okay, reseat the batteries into the slots to make sure the batteries are making proper contact.
If that doesn't work, then try new batteries just to be sure the batteries aren't the issue.
If it still doesn't work then leave the new batteries in and the usb adapter that comes with that mouse, hook it back up to the usb slot on the laptop and see if windows recognizes the mouse. If no messages come up then go into the device manager and see if the mouse shows up in there.
It will show up as either the type of mouse you have or a yellow question mark which would mean you need to reinstall the software for the mouse.
if nothing shows up in the device manager for the mouse then that means the mouse is bad and would need to be replaced.
Dec 01, 2009 | Microsoft Wireless Notebook Optical Mouse...
I followed all the directions its fully charged and showing up on the mouse but its not working at all
Open My Computer, Right quick C: then click properties. Select Hardware tab. Click on Device Manager. Find Mouse in the list. If there is an exclamation point beside it, select mouse and click properties. Look in the comment box to see why the exclamation point is there and fix the problem as suggested. If there is no mouse listed but you see an Other Devices column with an exclamation point, this is probably your mouse. In either case, the problem is probably the driver. Reinstall the driver and the mouse should work if everything else was done correctly. If this still doesn't work, you may have to download another driver from the manufacturer. I had to do that one time with a brand new HP wireless mouse. For some reason the driver on the install CD was not the correct one.
Nov 08, 2009 | Microsoft Wireless Mobile Memory Mouse...
Hp Pavilion dv1000 laptop wireless connection doesnt always work? Sometimes it shows that a connection is available but it wont connect. Sometimes it works fine but drops out right in the middle of what...
you might have to review the driver version of your wireless. try to check if there are updates that might fixed the bug. go to my computer, right click, manage, device manager, network adapters - under it move your mouse on top of the wireless, right click, properties, driver and check driver version and date. then go to your hp pavilion product support http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432999&taskId=135
and look for new version of network wireless driver might have. let me know if this doesnt fix the problem.
Apr 15, 2009 | HP Pavilion dv1000 Notebook
Strange situation that I am getting annoyed with. Here's what the deal is: I have a Wireless MS Intellimouse Explorer which actually works fine but, the intellipoint software (nor device manager) does...
Sounds like you need to update your mouse's driver, you will find the intellimouse 6.3 driver for Windows XP at the link below "IntelliPoint 6.3 32-bit for Windows XP".
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=MK&type=Mouse&name=m_imobt&os=XPSP2&lang=en
Feb 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Wireless mouse KU916AA won't connect to our computer, this was working, the computer is only 3 weeks old
My new wireless mouse KU916AA won't connect to my HP Pavilion dv 2000. OS is Vista
Nov 11, 2008 | Computers & Internet
HP Wireless Optical Mouse Logo
250 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
