Question about LG 37LC2D Television
Power problem fuse keep blowing - LG 37LC2D Television
  • 130 Answers
Hi
short in power suply module
Posted on Oct 06, 2010
I have a 2004 chevy surban that keeps blowing the ignition fuse what can cause this
You have a direct short to ground on that power feed circuit . You need to find a power distribution diagram to see what all gets is power from that fuse . Isolate the circuits till the fuse doesn't blow any more , then trace out that circuit that blows the fuse .
Which Ignition fuse ? Which fuse box is it in ? under hood , passenger compartment ?
IGN A
40A
Ignition Switch RUN, START, RUN/START/ACCY
IGN B
40A
Ignition Switch RUN/ACC, RUN/START
Could be ignition switch problem , Chevy has had problems with them .
Jul 06, 2016 | Cars & Trucks
Dodge radio problems
fuses blow because of excessive current flow from a dead short to earth. You haven't stated which fuse blows and what the items are covered by that fuse. so check the power wire from that fuse and trace it until you find a burnt area or a place where the power wire is touching the body before it gets to something it is running
Dec 22, 2013 | Cars & Trucks
Power window fuse keeps blowing
If a fuse keeps on blowing there are broken wires or a short in the circut controling them.
Nov 02, 2012 | Pontiac G6 Cars & Trucks
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
I have a 1997 mercury mystique and the power window fuse keeps blowing. What could be the problem?
When a fuse keeps blowing the problem is usually a short or open circuit that allows for the current to keep passing and blows the fuse
Mar 03, 2011 | 1998 Mercury Mystique
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Fuse keeps blowing
If fuse keeps blowing that means that there is a shortage on AC wiring or switch controlling the air conditioner.
Also an abnormal power draw from AC caused by an internal fault on AC can cause the fuse to blow.
Test wiring and switch with a voltmeter, the most common is that there is a short to ground between wiring and car body somewere.
Apr 29, 2009 | 2000 Chevrolet Malibu
No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
Mar 08, 2009 | 1999 Pontiac Montana
CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Dec 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
Televison & Video Logo
56 people viewed this question
Computer Repairing
Computer Repairing
