If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
Your battery is probably out of charge.... Try charging it.... If the red light keeps on blinking even after charging it for a sufficiently long time You will either need to 1. Change your Battery. 2. Perhaps change your charger.or get your charging port checked and repaired.
first check your batteries ,whether they are charged or not?and also try the hard reset method ,that is,remove the batteries and keep it removed for half an hour and then insert the battery and try again,it will help you
