Question about Spidem Trevi Digital Plus Coffee Maker
Coffee come out fast and is weak ... - Spidem Trevi Digital Plus Coffee Maker
  • 1,089 Answers
Hi
2 things can cause this.
1. the grind is too coarse. That would be the big knob in the bean hopper. Turn it down when its grinding only. From the factory it is set on 8.
2. The grinder has seperated internaly. That is a tough one to fix, as the grinder should be taken apart and cleaned, then reassembled.
Posted on Oct 02, 2010
LIKE DRINKING WATER WITH A HINT OF COFFEE
You have 3 selections, thus use #1 or #2 for a stronger brew. Naturally the water levels will differ. Get a Reusable Kcup device and pack your own coffee for better results. Get fine ground coffee or grind your own, and then pack the Kcup reusable with your grinds. A fast hot water flow is excellent.
Feb 11, 2014 | Keurig K75 Platinum Coffee Maker w/78...
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
Weak coffee the water appears to go through too fast
first give me your machine modal number.
if machine has bypass system then ,I can think that your spray head tube is blocked.
if water come from bypass then it comes very fast.
thanks
please rate me
Aug 18, 2011 | Bunn Coffee Makers & Espresso Machines
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
My baby gaggia is putting out water too fast resulting in weak coffee.
Adjust the coffee grinder to finer. (coffee grounds are too coarse)
Jan 17, 2011 | Gaggia Baby Espresso Machine
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
Sep 06, 2010 | Bunn Coffee Makers & Espresso Machines
Our Bunn coffee maker has worked great for two years, but all of a sudden when we go to make coffee, the water pours out FAST and not the normal slow drip and the coffee is weak weak weak...we have cleaned...
It sounds like you are missing your sprayhead. If you will call Customer Service at 800-352-2866 with the model we will be able to send you out a new sprayhead.
Aug 18, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
WEAK espresso from Saeco Vienna!
Well, when you set it that low it allows the water to pass very quickly and if the water passes very quickly there may not be sufficient time to absorb the coffee; hence weak coffee. The setting should be reset to the middle, at 10, and tried again. Then, if you want to change it move it only one or two numbers for enough cups to see if there is any change before you move it a large number. Going higher or lower makes it pass more or less quickly with results accordingly.
You may also have the dose set too low and you may want to set it higher increasing the amount of coffee in each dose.
Then again, since it was used, you don't know if the machine was taken apart by someone who reinstalled the machine with the dials you are using out of whack with where they should be set.
George W Conrad.
Apr 02, 2009 | Saeco Vienna Espresso Machine
My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Mar 18, 2009 | Keurig B60 Coffee Maker
Coffee is weak and watery
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
May 26, 2008 | Bunn BT10B Coffee Maker
Spidem Trevi Digital Plus Coffee Maker Logo
382 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
