Question about Microsoft Computers & Internet
I have install windows7 but now i want to install windows xp what is process of installing windows xp
  • 106 Answers
There are two ways to do it. the easy way and the hard way:
  • easy way is longer, you simply back-up your files, then reformat your PC and reinstall XP
  • the hard way is more technical, but does not require reformatting. please see link below for the set-by-step guide
http://www.intowindows.com/how-to-downgrade-from-windows-7-to-xp-step-by-step/
Posted on Oct 02, 2010
  • 590 Answers
1. Backup all the datas to external harddisk / pen drive / dvd.
2. Get windows xp installation cd. put it into your drive and restart your machine
3. you should get message like "Press any key to boot from cd". press a key to boot into windows xp setup screen
4. follow the instrutions and at last windows xp will be installed.
I hope this is helpful to you
Thanks
Driver
A solution that you can try (if your CPU has virtualization support):
- install XP mode on Windows 7, following the instructions from http://windows.microsoft.com/en-CA/windows7/install-and-use-windows-xp-mode-in-windows-7
- using Windows XP virtual sesiion, install the XP driver provided with your scanner and use it as before !
If your CPU doesn't support virtualization, you can try to install a virtual environment of Windows XP using VirtualBox application from Oracle.
Also, some answers for your problem you can find at http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Canon%20CanoScan%20N650U%20Scanner&vendor=Canon&Type=Hardware&tempOsid=Windows+7
Good luck !
May 23, 2014 | Canon CanoScan N650U Flatbed Scanner
Hi i have switched from win7 64 bit ro win7 32 bit, and now i have problems with video driver on my sony vaio vpccw21fx.
Hello Dron,
Earlier in your Sony Viao laptop the drivers installed is for Windows 7 64bit version. Now you have installed the Windows7 32bit. You have to install all the drivers which are compatible with Windows7 32bit.
Please visit the link provided below :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VPCCW21FXL&SelectOS=7
Please download the Windows XP drivers from the above link and install the drivers on Windows7 32bit.
Jun 05, 2011 | Sony VAIO(R) VPCCW21FXL 14" Notebook PC ...
My modem is supporting window 95/98/2000/XP/ME or window NT . I want to use this modem on Window 7_OS, can i do. what to do for this?
First check it compatibility with windows7 before installing or downloading. Install windows7 upgrade utility that show how your hardware supported to windows7.
Good Luck
Feb 26, 2011 | Computers & Internet
Hi all I have 945 motherboard, 1GB ram, intel 2.5GH proccessor whenever I tried to install Windows vista or Windows7 the setup start but It stops at windows7 logo(where four logo color gets together and...
If you are having problems installing windows 7,you might wnat to go into your bios main screen and see if your hard drive(sata mode) is set to IDE.If so,set it to AHCI mode,as any operating systems above windows xp will not install on IDE mode.Hope this solves your problem :)
Feb 22, 2011 | Computers & Internet
How do i install windows xp sp2 when i'am currently running windows7 on my pc?
Do not try it while in windows 7 it will not let you. I don't know what brand of PC you are using but I am assuming that it won't pull up the cd when you restart the computer. So if it is a dell like the one I am using right now. you will press F12 after you restart the computer then tell it to read from CD-ROM/DVD-ROM. on both occasions you need to keep an eye out for "boot from CD/DVD press any key" to start the process of installing Windows Xp. I sure Hope I have helped here Thanks, Cody
Sep 26, 2010 | Microsoft Computers & Internet
My cam is not compatible to windows7
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all. make sure you install and run all.any programs as Administrator.
Jun 07, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have an hp desk jet 3322 printer no cd need to install and configure can u help?
What Operating System do you have? If you have 2000 or XP here are the drivers:
Drivers for XP or 2000
Drivers for Vista + WIndows7
The alternative driver is Deskjet 3600
Or
HP itself for Drivers for Vista + Windows7
Installation
Also note once you get the driver if you are using a USB cable to connect it to the PC, that you install it like this:
1. Make sure the USB cable is not connected to the PC but connected to the Printer
2. Install the driver
3. When prompted then plug the USB cable into the USB port on the PC to complete the installation process.
Mar 16, 2010 | HP DeskJet 3322 InkJet Printer
Computers & Internet Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
