Question about Kenmore Washing Machines
I have a kenmore washer Model# 110.25066500 and the problem is when it starts to wash it will wash for about a minute and just stops and you can hear a humming sound like the motor is stuck. looked between basket and tub and nothing is there to jamm it.
  • kim_ayudan Oct 02, 2010
    I have a kenmore elite washer model# 110.25066500 runs for about a minute then stops and can hear motor humming, nothing is stuck between tub and basket, checked continuity on motor and mfd on capacitor checked ok. I'm pretty sure its mechnical.
  • 2,272 Answers
If the motor continuity checked ok and there is nothing got stuck in between the tub and basket then most probably the fault is related to the coupler between the motor and transmission or weak door switch. If door switch also shows proper continuity and proper voltage then other possibility is blocked drain pump,check the drain pump and drain hose for any kind of lint /debris got collected and any kind of other blockage in them. ----------- The pump is accessed from the bottom, which requires the washer to be laid down.To empty it you just have to scoop out as much water as you can.To access the pump the outer case of the machine comes off.There should be 2 screws holding the control panel down.Remove the screws flip the panel up then there is 2 clips holding the case remove them tip the case forward and pull it off. ------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 02, 2010
  • Kenmore Master
  • 17,130 Answers
Possible that the motor( if running with a capacitor assist) the capacitor attached to run is weak. You can see this capacitor strapped on the motor circuit.
The second possible fault can be the motor by itselff is getting stuck due to a poor bush play in the shaft and so it is sticking on between the run, this can be a little costly as the motor needs a new bush or a replacement. You can try and lubricate to see if this helps, if so remove and reset.
Finally check all the connectors from the program controller, make sure they are tight and fitting.
  • Donald DCruz
    Donald DCruz Oct 02, 2010
    Use a capacitor in parallel if the motor is humming and not running....with not friction as you mentioned.
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE TOP LOAD WASHER
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
Oct 29, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
107 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
