Question about GE Profile Harmony DPGT750EC Electric Dryer
Same problem with heating, need to locate thermal fuse
Can you send me a diagram
Is this some kind of sick joke i asked for something and you indicated you could help and all you did was nothing
Posted on May 02, 2009
I need to find the thermal fuse on my dryer, can you help
Posted on May 29, 2008
Behringer pmp1280s circuits diagram
sir,send me behringer pmp1280s circuits diagram .
send me my facebook pls....
Aug 05, 2013 | Music
No heat in dryer
Check your exhaust leading from your dryer because kinks and lint blockage are the leading cause for exhaust high temperature thermal fuse to burn out causing it to run with no heat. The thermal fuse for a front loading 110.88752791 is part number=> 3399849 Thermal Fuse
You may view the location number 15 HERE. The location 5 in that photo is the=> 3398128 Cycling Thermostat
How to check these parts can be found on the same above pages, If rhe model I listed is not your model let me know and I will send you links to other models with the same model number as 110.88752791, Thank You Sea Breeze
279843 Heating Element Assembly
Nov 07, 2012 | Dryers
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Aug 09, 2011 | Amana NED7200TW Electric Dryer
The Whirlpool 3RAWZ480E is running normal the problem is " no heating"
More often than not a no heat condition is caused by a failure of the heating element in electric dryers. Less frequent but just as likely is a failure of the thermal fuse which is located on a portion of the internal ducting where heated air passes through. The thermal fuse will disable the heating element in the event of uncontrolled overheating, which may have been caused by a malfunction of the temperature control thermostat or a malfunction/failure of a thermal circuit breaker.
Inside the appliance, either in the main cabinet or inside the control enclosure you will find the circuit diagrams and parts listing. If you feel confident in doing the repair yourself, these documents will help you locate the components of the system and give you the part numbers you need to order replacements. Make sure you disconnect from power before opening the cabinet. An inexpensive multi-tester will be all you need to check continuity of the components in the heating circuit.
Jun 30, 2011 | Dryers
My kenmore elec. dryer 67042 model wont get hot...I never recd a manual..need diagram to dis assemble and examine the unit! Can u help me find a diagram?
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore Dryers
On the Kenmore series 90 electric dryer, where is the thermal fuse located.
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Jan 06, 2010 | Kenmore 73952 Gas Dryer
Maytag Dryer getting hot and then shutting off
if will heat for a short time its not a thermal fuse but the vent tube or hose is crushed or plugged put unit on air only go to the location where it exits the vent if you feel no or low air then find the area of the vent system that is affected.
Jan 01, 2010 | Maytag MDE9206 Dryer
I need a diagrams of a Lexus GS 300 1994,3.0 engine timing marks
I have the diagrams if you send me your email I will send you the diagrams.
Oct 05, 2009 | 1994 Lexus GS 300
I need a fuse box diagram for a 1992 honda civic. Thanks
I have the diagrams you need. There are two different configurations under the hood for your fuse diagrams but I can send both to you along with the one inside of the car. Send me your email and I will send you the diagrams.
Sep 22, 2009 | 1992 Honda Civic
GE Profile Harmony DPGT750EC Electric Dryer Logo
172 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
