Question about Maytag 24 in. MDB4100 Built-in Dishwasher
Soap is not dissolving and dishes are not cleaning does not appear to be filling up with enough water
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Samsung DW80J7550US not filling with water, strange noises, leaving dirty dishes
Just answered a similar question. Check the float switch at the bottom of DW. There should be a float switch that can be pressed down and should pop up. It should have a cap that can be removed to clear any debris. The switch monitors how much water is used so that it does not flood.
Sep 18, 2017 | Samsung Dishwashers
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
It is not filling up with water enough to dissolve the soap pack or clean dishes properly
if this is a new washer you must prime by hand first. meaning put some water in by hand first,about 1 gallon.
Jul 14, 2009 | Dishwashers
Soap left in cups when cycle is over
If the problem is that the dishwasher isn't filling with enough water, you should replace the water valve.
If it's getting enough water, but dishes have a white film on them or are still not getting clean, you may have hard water build up in your machine. Try to run a dishwasher cleaner thru it, or depending on how much buildup you have, you may need to take the dishwasher apart and clean it. I know JetDry puts a cleaner out, but I haven't personally tried it yet.
You can usually see white buildup inside the dishwasher if this is your problem.
Apr 07, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
52 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
