Question about Dell M992 19" CRT Monitor
Power but no display
My M992 powers up but there is no display. It has been in a closet for about a month and was working fine before it's temporary retirement. Not even the Seft Test Feature Check. Any ideas on what the problem may be? Is this worth having someone else repair?
Thank you in advance for your help :-)
Bill H.
  • Bill1963 May 26, 2008
    There is absolutely no display. I cannot check any settings. I swapped monitors and my other one works fine.The manual indicates that while not connected to the computer, the self-test feature should be displayed.
    http://support.dell.com/support/edocs/mo...
  • Bill1963 May 27, 2008
    My other monitor is a dinky little 15" that I use as a backup so I would really like to get this 19" flat screen working. Again, I have power but there is absolutely no display or signal of any sort. I cannot check settings at all. The STFC (Self Test Feature Check) that should appear when the monitor is plugged only into an outlet doesn't even come on. Is this something that I can fix or is this particular monitor worth the investment of having someone else fix?
    Thanks again, in advance, for any help that is offered.
    Bill H.
  • 1,031 Answers
Does the screen show no signal, it could be from thedigital button setting on the monitor try to adjust the setting,
2.check the video card ,you can test it on another system,test the monitor on another systems thats working fine if it continues may be its frm the systems or the monitor tube is bad if your using the correct resolution
Posted on May 26, 2008
Tip
Help - My Bedroom Doesn't Have a Closet for Hanging Clothes
Most bedrooms come with built in furniture closets for hanging clothes. But sometimes you come across apartments that don't have any facilities.
Here are some suggestions for what to do if you bedroom is lacking in a hanging space.
1. Check out some of the cheaper furniture stores. You might find that you can pick up a closet for a lot less money than you realized.
2. Buy a moveable fold-up closet. You can get ones made of canvas or plastic that can be folded up and packed away when you don't need them. They're not as stable as wooden closets but make a great temporary solution.
3. Use a shower rail or pole that you can attach to 2 sides of a wall. This can provide a secure hanging space without needing a big purchase.
on Dec 16, 2013 | Retail Supplies
My Dell M992 monitor screen is blurry and there are squiggly lines running through it. The color is perfect. I even changed the resolution with no luck. Is it time for a new one or can it be fixed? I...
Check the cable going from the pc to the monitor and ensure the connections are secure. You also may want to try moving the cable away from any other power cords if possible.
If this does not help then most likely it is time for a new one.
Nov 12, 2009 | Dell M992 Monitor
No power
OK disassemble the monitor and visually check for bad components or cold solder here is a couple of examples.3bf0ae5.gifcold solder12cd393.jpeg bad capacitor
Jul 05, 2009 | Dell M992 Monitor
Fax machine won't power up
Try pushing the power cord firmly into the back of the machine
Jun 22, 2009 | Panasonic KX-FM220 Plain Paper Thermal Fax
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
Out of frequency
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Dell M992 19" CRT Monitor
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Dec 19, 2006 | Dell M992 19" CRT Monitor
Dell M992 19" CRT Monitor Logo
130 people viewed this question
Alun Cox
