Question about Gateway FPD2275W LCD Monitor
Gateway FPD2275W Monitor not working
My daughter shut down the computer and monitor using the power strip because the system froze and the power button on the computer did not respond even with her holding the button for more than a minute. when she turned the power strip back on and tried to turn the system back on only the computer powered up, the monitor would not. there appears to be no power to the monitor as the led is not illuminated. we have tried a new power source, another power cord but nothing is working. gateway was not able to identify the cause (we tried all their suggestions) and they are suggesting we buy a new one even though this is only 14 months old (bought Mar 2007). Any ideas or suggestions?
Thank you.
Mike.
Did you try the fuse. chances are the power supply is at fault but if the spike of voltage was sufficient enough it may have taken out the fuse first.
Warning: If you dont feel comfortable around electronics Do Not Attempt to remove the case from your monitor as HIGH VOLTAGE is present even after the unit has been turned off for a long, long time.
The other option is to find a local repair shop in your neighborhood which will give free estimates. Dont take it somewhere where they'll hit you up with a fee to look at it.
Posted on May 30, 2008
Gateway monitor FPD2275W TFT LCD powers on, gateway logo goes on fine with brightness then monitor brightness drops so you can barely see it. Not sure if this is a problem with the brightness setting or...
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Dec 22, 2010 | Gateway FPD2275W LCD Monitor
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
Power will not turn on
You need to open it up and look for bad caps with bulging top first just a start, post back what you see so we can guide you further, see example of failed Gateway monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | Gateway FPD2275W LCD Monitor
When I power up my computer the Gateway icon shows up but monitor stays black...I repeatedly hit the power button on the monitor until the screen finally shows up..and once its on it stays on all day until...
hi, these are exellent monitors. i have repaired and made good profit on these. there is about 8 capacitors on the main board that go bad. all are 470uf 25 volt. if you have good knowledge of soldering, you can perform this repair. even broken, these monitors go for 100 dollars on ebay. contact me back if you want more info on how to repair yourself.
Feb 08, 2010 | Gateway FPD2275W LCD Monitor
Monitor lights up the power light and automatically turns off.
Make sure the problem is not from your video card. It may not recieve signal from the card and automatically shut down. Try the monitor on another computer.
Nov 30, 2009 | Gateway FPD2275W LCD Monitor
My computer says power saving mode
does it shut down when the message appears?
Jul 24, 2009 | Gateway FPD2275W LCD Monitor
Monitor goes blank after it comes on for two seconds
bad capacitors on the power board internal to the monitor they need to be replaced, let me know what you would like to do
Mar 22, 2009 | Gateway FPD2275W LCD Monitor
Power saving mode.
Your power system goes down.
Apr 21, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
217 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
