Question about Toshiba 26 26AV502R 26 in. LCD HDTV
This tv keeps blowing fuses. what should i check next
I have 2 toshiba model # 26av502rz. they were not hooked up to a surge protector when the house got zapped withe 240volts. now they do not work. is it just the fuse that needs to be replaced and how do i find one?
Posted on Apr 14, 2011
  • 130 Answers
Hi
you should check these 2 inverters 1on each side of the tv
Posted on Oct 02, 2010
Hello, I have a samsung un55d6400 led tv, where the standby light blinks 5 times, ive replaced the powerboard and main board. The fuse keeps blowing what is my next step
The fuse keeps opening because the problem is more serious. If it did not blow, then more damage could be incurred in the TV. Sounds like you should consult a professional rather than not really knowing what you should be doing next.
Dec 05, 2016 | Samsung Televison & Video
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
Blown fuse
shorted component.
check rectifiers.
check filter capacitor check transistors!
Dec 06, 2007 | RCA F38310 38" TV
Blown fuse over and over
you need to solder all the connectors and plugs between the 2 boards
Mar 05, 2007 | Toshiba 42H81 42" Rear Projection...
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Toshiba 26 26AV502R 26 in. LCD HDTV Logo
390 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
