Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Can't connect to my linksys wrt54gx2 router and even when I do, it tells me there is an ip address conflict and disconnects me
  • 106 Answers
  • make sure the DHCP server is enabled on your router
  • your LAN TCP/IP should be set to "obtain IP address automatically"
  • check DHCP client table in your router if there is anyone trying to connect to your router illegally
  • try to enable MAC filtering on your router wireless security
Posted on Oct 02, 2010
  • 78 Answers
Try to connect using a LAN Cable (Wired) connection. and then try to access 192.168.0.1 you should be able to see wireless settings there.
IP address must not be the same with the IP Address of other computers in your house. look for the Range and Increase it so that the router could have a wider range of IP Address to choose from.
I have two computers plugged into the srx200, there are conflicts when we both try to get on the internet at the same time. Would having indentical ip addresses have something to do with it?
Most of the cases at problems like these is that both the computers use the same ip address. I suggest you to change the ip settings to auto, so that each computer will get an ip from the router and no conflicts will occur.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Linksys 4-port Wirelss Router W/srx200...
I can't connect to the internet using my Linksys WRT54GX2 router
is your pc wifi enabaled? if so then do these seps>>
this is the easyiest way.
click connect to(or the connection buttotn)>>connect to the router/internet accesspoint>>after getting connected right click on the connection>>
status>>properties>>networking>>(double click)internet protocol version( u will see two of them do both of them one after one)>>check obtain ip address automaticaly(both)>>check obtain dns address automatically(both).
now close the windows and try to connect again.
let me know what happened
Mar 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
No wireless light
Have you tried to check the IP address that you are getting from the router on your wired computers? If they are getting an IP address of 192.168.1.10x and the DG: 192.168.1.1 then that is the right address to get in to the router. Did you try to ping the address? did get replies? try to also disable the firewalls on your pc.
Jun 20, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Router
Before you can get online through the router all you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
Just reply to my post to let me know if your done doing this. We will setup the wireless after we make sure that you can get online wired to the router.
May 13, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Dec 20, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
WRT54GX2
If you are unable to access the router through the usual ip address you will have to reset the router
Oct 10, 2007 | Linksys Wireless-G WRT54GX Router...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
