Question about HP w19 19" LCD Monitor
I have an HPW19 wide screen monitor that goes to black.
I turn it on the power lite stays green the whole time. after about 3 seconds the screen goes to black. Then after about 10 seconds I can see video again then it goes back to black after another 3 seconds then stays black. any help?
  • lolevi Aug 10, 2008
    I have an HPw19. I starts up with Windows XP and then says Input not suported. I sent the unit away for a new one and the new on is doing the same thing. I cannot see anything but the black screen and the floating message. Is this a software or hardware or a cable problem?
  • Don Mccormick Jan 02, 2009
    I have had my HP19W monitor that came with my ac1347 equipment. About a year I complained to HP that my power switch was not waorking right. After a number of calls with their tech support (in India??), I got a call from tech support in Canada who got me a new monitor. I think HP has a problem with the power switch/button. This monitor is not my choice of a good product!!!!!
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
Posted on Dec 09, 2009
  • 139 Answers
To be sure the system is actually on press the caps lock key when on if it comes on then yr problem should be from screen display.what to do.
*disasemble the screen area then check the module,conector then the screen itself to know the actual problem. most times when u lose and tight back u find the problem solved so try it out.
hope this helps
rate me plz
Posted on May 26, 2008
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
Monitor won't stay on. each time I turn it on it comes up for about 3 seconds and then goes black
aburnsrn, Cold-cathode-fluorescent-lamps don't light-up, you will be looking at black screen!! If unit older than 5-6 years trade for new wide-screen. Else read for about 2 hrs. in my fixya profile for more options.
Feb 27, 2010 | Acer AL1917W LCD Monitor
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
Black screen green lite on/flash right green lite off
The problem on your monitor is a bad power supply. We you can solder you should be able to repair it. If you check our site at : We have a monitor repair section with dis-assembly guides and repair procedures. I will post a Hanns-g guide tonight. This will show how to open and repair the monitor. We also have a repair parts kit available. If you don't want to do the repair yourself then we can do it for you, just email me if you have questions or wan tus to do the repair for ou.
I hope this helps.
Corporate Computer
Aug 05, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
HP w19 19" LCD Monitor Logo
570 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
