Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I put half a small lemon down the garbage disposal. The disposal kept working fine with the water running, but then it violently threw out water and food particles. I stopped the disposal immediately, the other sink beside it started spitting water out, too. I waited for the water to drain down and pulled what food I could out of it and turned it back on. It did the same thing. I'm house sitting for friends and need to correct this. Thank you.
  • 377 Answers
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain. Sounds like a clog that was there prior to you putting the lemon in the GD.
Posted on Oct 02, 2010
Smelly garbage disposal
Patricia,
I would suggest putting some lemon juice in the disposal and let it sit for a short period of time and then run hot water down that drain while the disposal is running. Hope this helps!
May 21, 2015 | Garbage Disposals
Tip
How to Sanitize Your Dishwasher
Step 1 -
Get rid of any odor that may be coming from the plumbing pips your dishwasher shares with the sink. Pour a half of cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all of the baking soda is washed away. After five minutes, run very, very hot water down each of the drains.
Step 2 -
Clean out your garbage disposal. Slice a lemon/lime and put the slices down your disposal drain. Run your disposal with cold water running.
Step 3 -
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process is that does not clean up all of the build and film. You can use baking soda and bleach instead of vinegar - just sprinkle the baking soda in the bottom of the dishwasher tub, and pour bleach inside the tub as well.
Step 4 - Between washes, pour 1/4 cup of lemon juice into the dishwasher cup and run a short, but complete wash cycle. This will not only deodorize the dishwasher but will also help get rid of any metal build-up.
on Oct 19, 2011 | Frigidaire Dishwashers
Tip
HOW TO CLEAN THE INSIDE OF YOUR GARBAGE DISPOSAL.
Cleaning Your Garbage Disposal.
To improve the performance and longivity of your garbage disposal you should clean the iniside of the machine monthly. Gunk builds up inside of the disposal things suchas, grease, dirt, peels, etc... The following is extreemely effective in removing all types of material from your disposal and will also leave it smelling great.
FIRST STEP.
GRAB (2) ICE CUBE TRAYS FORM THE FREZER.
  1. CRACK THE CUBES FROM THE TRAYS AND PUT 6 TO 8 CUBES INSIDE THE DISPOSAL (THE DISPOSAL SHOULD BE OFF WHEN YOU ARE PUTTING THE ICE CUBES IN).
  2. AFTER PUTTING 6 TO 8 CUBES IN THE DISPOSAL TURN THE UNIT ON AND RUN TILL THE CUBES ARE GONE. REPEAT THIS UNTIL BOTH TRAYS OF CUBES ARE USED UP.
  3. AFTER THE ICE CUBES ARE GONE RUN THE DISPOSAL WITH HOT WATER RUNNING THROUGH IT FOR ABOUT HALF A MINUTE.
  4. AFTER RUNNING THE HOT WATER THROUGH THE DISPOSAL PEEL A LEMON. DISCARD THE PEEL IN THE TRASH. PLACE THE WHOLE PEELED LEMON IN THE DISPOSAL WITH THE DISPOSAL TURNED OFF. START RUNNING HOT WATER AGAIN AND TURN ON THE DISPOSAL. RUN THE DISPOSAL UNTIL THE LEMON IS GONE. TURN OFF THE HOT WATER AND RUN COLD WATER THROUGH THE DISPOSAL FOR A FEW SECONDS AND TURN OFF.
The inside of your disposal is now sparkling clean and smelling good. If you use your disposal a lot do this cleaning once a month. If you don't use your disposal much do it every 3 months. Your disposal will work and smell much better. THANK YOU.
Submitted by: Tom McArthur (retired contractor)
on Jun 12, 2011 | Plumbing
Insinkerator 100ss sounds like it is running but does not empty the food completely out, thus causing stink! Please help.
run water while unit is on
add ice cubes with water running and unit on
until all food particles are gone
ice and lemon for a pleasant sent
Sep 15, 2012 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The unit hums but does not work. I tried using the wrencette, broom handle and even electric drill but no luck. When I used the wrencette, the unit moves with slight resistance. When I tried to move the...
Hi, chances are the unit is clogged and just needs to be cleaned out. Be careful not to run the unit while it is clogged or it will overheat and be useless. Hope this helps.
Nov 16, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Tip
How is the best way to use a Garbage Disposal
Garbage disposals can be a great feature in the kitchen if there are used correctly. If they are not used correctly they can be a real pain to get unjammed or to get them cleaned out.
To keep a garbage disposal from smelling up the kitchen, proper use and care must be followed.
There are certain foods that a garbage disposal will handle well and there are some that do not do very well in a garbage disposal.
Some that do well and you can put into the garbage disposal are:
1. soft bones, like chicken or fish bones
2. ice cubes
3. coffee grounds
4. citrus fruit peels
5. store bought disposal deodorizers and cleaners
Some foods that do not do well are:
1. very fibrous vegetables, like onions, corn husks, celery, etc…
2. hard bones, like beef or pork
3. large pits, or seeds like peach seeds
Also, while it is good to run water while grinding food in a garbage disposal, it is not a good idea to run very hot water in the disposal. This can cause the motor to over heat.
Do not run the garbage disposal longer then a half minute after the food id ground up. Running an empty garbage disposal can cause excessive wear.
It is also a good idea to start a full stream of water and the garbage disposal motor before putting large quantities of food into the disposal. Staring the motor with a large amount of food inside the disposal is hard on the motor, and may cause a jam.
http://www.fixya.com/support/r4062688-garbage_disposal_smells
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
on Feb 06, 2010 | Dishwashers
Tip
Garbage Disposal Smells
What can you do if your garbage disposal starts to stink up the kitchen? Because of the stuff that you put down the disposal and grind up the residue can sometimes start to create a foul odor that can be noticed in and around your kitchen. To combat this problem there are some general things that you can do and also some things that you and grind up in the disposal that will help to keep it smelling great.
One of the things that will make the disposal smell bad is if your dishwasher discharges through the garbage disposal. The food left after the water goes through will soon start to spoil and stink. Make sure that you run your disposal after the dishwasher runs to clean out the food and keep the disposal clean.
Some soft foods like meats and cooked vegetables will also tend to stick to the plate of the garbage disposal. These will cause a smell to develop after a time as they breakdown. To stop this from happening keep harder foods or foods that smell better for last to run down the disposal. This will help to clean the plate and keep the garbage disposal smelling better.
If you are going to be away for a long time, or you are having friends over and want your garbage disposal to smell good, you can use a lemon or lemons rinds. Cut up the lemon and grinds it up before you shut down the disposal. This will have your garbage disposal smelling great!!
There are also commercially produced garbage disposal cleaners, deodorizers, and degreasers, that you and buy at most grocery or hardware stores that are made specifically for this purpose.
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
on Feb 06, 2010 | Kitchen Appliances - Others
We are getting a strong odor from our two compartment dishwasher, would welcome any suggestions
Get rid of any odor that may be coming from the plumbing pipes your dishwasher shares with the sink. Pour a half a cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all the baking soda is washed away. After 5 minutes, run very, very hot water down each of the drains.
Clean out your garbage disposal. Slice a lemon and put the slices down your disposal drain. Run your disposal with the cold water running. You can use just the lemon or an orange rind if you don't have a whole lemon.
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process if that does not help. You can use baking soda instead of vinegar - just sprinkle it in the bottom of the dishwasher.
Between washes, pour ¼ cup lemon juice into the dishwasher cup, and run a short but complete wash cycle. Is will not only deodorize the dishwasher, but will also help get rid of any metal build-up
Nov 03, 2010 | Fisher and Paykel Dishwashers
The garbage disposal has a slow drip from the bottom, can this be fixed?
If the garbage disposal is rusted out, then it can't be fixed.
My first instinct is to check other sources of leaking water first.
Maybe you have checked, and the following information is not necessary.
Here's some things to do:
1) Fill the sink without letting any water down into the disposal.
Let the water stand in the sink for a while.
Do you see any water dripping?
If you see water, then that tells you the putty seal at the sink strainer is leaking.
Pull out disposal, remove old putty and replace with ample amount of plumber's putty.
2) Next suspect is where the tailpiece connects to side of disposal.
The tailpiece lets the water flow out of disposal
The tailpiece is usually sealed with a rubber gasket
This rubber gasket can leak
Take it apart. Is the rubber part wet on the outside?
You might be able to buy another rubber gasket... but not likely ...
Good news: you can also seal up this kind of gasket using Rectoseal
Rectoseal is a brand name for a gooey pipe joint compound.
I like it because it's so gooey, and you smear in on with a bush that comes with the can.
Cover the outside of rubber gasket with plenty of rectoseal and then reassemble and see if leak continues.
Use Rectoseal on the washers when putting together any tubular drain pipe under the sink
3) Last suspect is the rubber hose that feeds into the garbage disposal from the dishwasher.
Does your garbage disposal leak when the dishwasher is running?
Try running dishwasher without putting any water down the sink
The rubber dishwasher hose connects to disposal with a clamp.
4) If the water leak is small, I use klenex tissue as a tester.
Tissue shows the smallest amount of water
Put the tissue on a damp area and it shows on the tissue
Start at the top of disposal and work your way down until you find the origin of the water.
Hope we saved you a dollar.
Oct 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
269 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
