Question about Mitsubishi WS-55411 55" Rear Projection Television
POWER UP TV will not power up , powe light comes on for about 1-2secs and goes off , you can hear like a relay or something
  • Ed Baker Aug 20, 2008
    I have the same problem. I checked the fuse.
    What and where is the horizontal transistor thats close to the lines transformer and see if its bad if not then resolder all open circuits and broken lines
  • billcooper Aug 29, 2008
    Same problem here, although until a couple of days ago, if you powered off the tv you had to wait a minimum of 10 minutes to turn it back on. Now 1-2 seconds and nothing but the on/off click of a relay.
  • 27 Answers
Check the thing on the inside, it might be bad
Posted on Mar 08, 2010
I have the same problem power light comes on for 1-2 secs and goes off.
What/where is the horizontal transistor that is close to the lines transformer?
Posted on Aug 20, 2008
  • Ed Baker Sep 08, 2008
    I took it to an authorized service shop and they told me it was the Deflection Power Board/Power Supply Board. They told me they could not fix it at the component level. Mitsubishi has a three year warranty after their 1yr they don't tell you about I learned it from Consumer Affairs. My TV is out of both warranties. The service store charged me $95 to look at it and wants $600 more to fix it. The Deflection Power Board costs $260, but Mitsubishi will not sell it directly to consumers.
    Scholar:
  • 139 Answers
Check the horizontal transistor thats close to the lines transformer and see if its bad if not then resolder all open circuits and broken lines
hope this helps
rate me
Posted on May 26, 2008
Hitachi 52fdx20b TV; power light will not turn off when TV is turned off.
if power light is on most of the set inside is on.
Follow power cord inside set and on power supply board look for up to three rectangular black relays that are there-----they will be marked with relay voltage in white.
Gently tap with something not metal on each until the power light goes off.
What happens is one of the relays sticks in the closed position.
If the power light goes off when you do this the relay is bad and if there are three the part number is printed on them----replace all three as they each have only 4 solder connections and are generally under 10 dollars each (wholesale about half that).
If tapping stops it sooner or later it will do the same thing again.
SD TECH
Sep 21, 2011 | Hitachi 57F710 TV
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Tv will not power up. green light comes on for
I have the same problem, did you ever get yours fixed if so what was the problem
Aug 17, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Red Light comes on and goes off/Relay clicks
hitachis are known for bad relays S901? part #fj00142
Jul 31, 2007 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
