Question about Philips Audio Players & Recorders
Instructions to use sbc vl 1202
Cant seem to get signal do i plug into my tv or cable box
Benimur
  • 6966 Answers
SOURCE: 20" sony trinitron KV-20fs100 no signal
If you have confirmed that there is cable signal but the Sony TV does not sense it, then perhaps the problem is internal to the TV. Primary suspect would be the tuner block/assy and/or its B+ supply. Often there would be two (2) voltages required; 12VDC & a 33VDC (varying). In some instances it could just be the zener diode.
The above of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
jerryg50
  • 1689 Answers
It is very possible that the tuner and IF modules have failed. On more rare occasions, the supply voltage to these modules may be missing because of failed components in the regulator circuit that feeds the front end area.
Some other areas of failure can be the uPC controler may not be addressing the front end functions, or the input switching control is not working properly.
The mentioned problems would require an experienced TV tech who has the service manuals, and the tools and facilities to troubleshoot and service your set.
If you decide to have the set serviced ask for an estimate. It may be expensive to fix.
Jerry G.
Posted on Oct 01, 2008
SOURCE: no signal when hooked up with a digital cable box
I had the same problem and had the cable guy out and everything thinking it was my box. I figured it out by myself here is what i did to fix it. I have the vizio 32 inch hooked to an hdmi cable and through the cable box i had the aspect ratio on 1080i and i should have had it on 720p once I switched it I havent had the problem since.
Posted on Dec 21, 2008
gripfitter
  • 557 Answers
SOURCE: No signal when cable is plugged in
check your input make sure it is set to catv (cable)
Posted on Oct 21, 2009
SOURCE: "Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Posted on Mar 02, 2010
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
Sharp 20 flat screen TV
if you go through a cable box, the box has to be reset or its bad.If it has a cable box, unplug from back of box and plug back in after 60 seconds and see if this works. Some boxes will count down to reset them
Sep 14, 2016 | Sharp Televison & Video
My Dell LCD Model W2606C will not process a cable TV signal suddenly. All else seems normal. Any idea what could cause that to happen.
Welcome to Fixya. If your tv cant process a TV signal most likely you are on the wrong input. We can check if the input that has been set to the LCD is correct. Can you please provide if the LCD is connected to a cable box and what cable is connect from the box to the LCD.
Thanks
Jun 22, 2011 | Computers & Internet
Setting up this system, i can t adjust the volume when attached to the TV with the RCA leads. Seems to come through at a set volume. Works fine on its own, but cant hook it up with my excisting system
Drawing audio from a TV has its limitations. Refer to the TV's manual regarding volume control of the audio OUTPUT.
If you MUST go this way, I'd still suggest using a Fixed output so you can turn the TV's speakers down or off without killing the signal to the Curtis. (TV's are on the low end of the audio food chain and actually will degrade rather than improve it.)
You could get the BEST possible TV-related audio directly and digitally from the source you're watching.
Jul 03, 2010 | Curtis DVD5091 Theater System
WeatherX Portable TV and the Digital Signal --- HELP
I haven't done this, but did find information that might help.
Watch A Battery TV With A Converter Box
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
Jun 12, 2009 | Casio TV-880 2.3 in. Handheld Television
I cant figure out how to plug in the direct tv cable
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Mar 07, 2009 | Akai LCT4216 42 in. LCD Television
I cant get my dvd to play using my rf modulator
instead of plugging in the rf modulator before the cable box, i plugged it in after it
Jan 24, 2009 | GE 25GT240 25" TV
How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Sep 25, 2007 | Televison & Video
149 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
