Question about GE Spacemaker JVM1640SJ Microwave Oven
Good Evening; I have a GE Spacesaver XL-1400 microwave. Currently I have no power to it and can't figure out how to turn it back on (if that's what's needed) Earlier this evening I switched off the circuit breaker for the Hot Water Tank ONLY. I turned it back on about 1/2 hour later. I didn't think OR don't know for sure that the microwave is on the same circuit. Anyway, that's all I've done that may have caused it. I did get a step stool and get up to the back of the cabinet and unplugged and replugged the power cord, but that didn't help. Any ideas? Kim Caruso, Tukwila (Seattle) Wa. :-) Thanks in advance for your help!
SOURCE: GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Posted on Sep 03, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
SOURCE: ge microwave spacemaker XL 1400
I did research and found out that the GE Magetetron (sp) are notorious for going bad. I called and it was still under warranty - 10 years, but i needed to pay for labor. That ran me $180. The part was $125 but would have taken my time to install, plus I didn't want to deal discharging the capacitor.
Posted on Apr 14, 2008
SOURCE: 1985 GE Microwave Spacesaver Uninstall
I CAN'T FIND THE SCREWS TO ATTACH THE TOP OF THE SPACE SAVER TO THYE BOTTOM OF THE UPPER CABIONET, WHAT SIZE OF SCREW IS THIS. WHY DOESN'T IT HAVE A NORMAL SCREW, I ALREADY WENT THROUGH ALL THE SCREWS THAT LOWES HAS.
Posted on Aug 25, 2008
  • 108 Answers
SOURCE: GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Posted on Nov 19, 2008
GE spacesaver xl just died. No fan, no lights, no power. Where should I go to repair? I live in Las Vegas
Might want to check the 20A fuse by the power supply before you haul it somewhere and they charge you a service charge for a cheap fuse...
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1400 Spacesaver is not heating things up AGAIN!
It's what, about 7or 8 years old? I'd buy a new one on sale. Probably not worth messing with just to squeeze out another year or two. You can pull out the Capacitor and take it to any electronics appliance repair place and have it checked for little or nothing, but if it's bad and you order a new one you have no microwave for a while. IF that's the ONLY thing wrong you're back in business.
Mar 30, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver 1400 does not heat
The most common fault with not heating is the high voltage fuse. I advise to either take it to a authorised repair agent to prevent shock or injury as many components still hold a large charge even after being switched off. Otherwise reply to this post and I will talk you through how to repair.Good Luck.
Apr 15, 2010 | GE Microwave Ovens
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave spacemaker XL 1400 stopped heating. 8yrs old
heatman101
hdj
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver 1800 XL - rattling sound
Hi jnflanders,
You've probably solved this by now, but I'll answer just in case. That part is called the stirrer motor. You can replace it yourself, as long as you have an offset phillip's head screwdriver handy.
Before you order the replacement part, figure out if your stirrer is driven by a d-shaped or a square shaft. You can tell by taking off the round plate on the inside top wall of the microwave. GE makes stirrer motors for both d-shaped and square shafts, so you'll have to get the right one. Here's the d-shaped motor that fixed this problem with my microwave: http://www.appliancepartspros.com/part_details.aspx?part_id=2024961.
Apr 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with www.martinmicrowave.com for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
41 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
