7 blinks on my 42PF7320A137 Phillips Flat Screen TV
  • 130 Answers
Hi
am afraid there nothing for you to do exept
to contact your local repair shop
Posted on Oct 02, 2010
No picture philips tv red light flashing 6 slow 4 fast and no sound model #42pf7320a137
Direct your question to Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 27, 2015 | Philips Televison & Video
Tv blinking on and off
hi have look on power supply for bad capacitors
Mar 16, 2014 | Philips 47PFL3603D LCD TV
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
Tv will not come on
Philips seem to have problems with their power supply boards. Often it may just be several bad capacitors in the power supply, which can be changed fairly easily. Otherwise the power supply board needs to be replaced, which is a $200 part.
The number of times it blinks tells you the 'blink code' with four blinks being the most common. The blink codes are not very accurate, but they help to give a tech a starting point in troubleshooting.
Oct 22, 2009 | Televison & Video
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Mar 18, 2009 | Philips Televison & Video
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from tritronicsinc.com
Dan
Jul 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
