Question about Gateway FPD1975W 19" LCD Monitor
WHERE CAN I PURCHASE A FPD1975W POWER CORD FOR MY GATEWAY MONITOR?
  • 11,361 Answers
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
My moitor fpd1975w blinks blue power button and a white screen but does not turn on ?
The blinking power light is a good indication of a failed power supply board and the white screen backs that diagnosis up. Here is a link to information show what to look for and replace on the power supply board to get the monitor back up and running again. The repair involves replacing parts called capacitors on the power supply board and can be done in less than 20 minutes once you have the parts needed.
I hope this helps,
BuddyMc
When I turn on my computer the monitor stays on for about 30-60 seconds and then turns off..I hookded up a different monitor with a different VGA cord and it works perfectly..I also tried changing out the...
The power printed circuit board is failing, not
delivering the proper power to the main board and/or the back lamps. One can
have this board repaired inexpensively by a electronic technician. Email me at Sprint6@zoominternet.net
and we may be able to get your unit working properly again.
Dec 14, 2010 | Gateway FPD1975W 19" LCD Monitor
I have a gateway FPD1975W tft lcd Monitor. It will not power on at all. I took the power cord from an exact same working monitor and put it in this one and it still will not power on?
Faulty power PCboard. Reasons and the exact problem may vary. Main components to check: The fuses, the stabilizing capacitors on the low voltage, the impulse transistor, the optron and the pulse width modulator (PWM) IC.
Jun 15, 2010 | Gateway FPD1975W 19" LCD Monitor
Where can i find a power cord for my fpd1975w 19 inch monitor?
bring your power cord set and go to electronic or computer sales shop
Oct 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway 900g no power
Try a different working out to make sure its not a wall outlet issue.if you do that and your still not getting power then the monitor is bad and would need to be replaced.
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back it...it should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
MONITORS
Inverter Power board 19 Gateway Monitor FPD1975w
Apr 09, 2008 | Gateway FPD1975W 19" LCD Monitor
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
