Question about Health & Beauty
DO YOU HAVE A INSTRUCTION MANUAL FOR THE INSTYLER HOT IRON
3 Suggested Answers
cooltroop2
  • 5 Answers
SOURCE: Instruction Manual for Rowenta surefine Inox Steam Iron Model DE-57 1C
Ah, simply search for it online, or go to the manufactors website. I am sure you will find it on the internet.
Posted on Jul 22, 2012
ercupa190
  • 12223 Answers
SOURCE: I have been given this iron but I dont have an instruction manual and the iron makes a kind of I need an instruction manual for delonghi PRO1100 iron system
go to www.retrevo.com or www. manualslib.com and get it by free
God bless you
Posted on Nov 29, 2013
How to fix it?i put it on 220 and its 110
sorry but there is not fix for that .
Oct 23, 2015 | InStyler Rotating Iron
Toastmaster model 265 user manual
Indicator light shows the the heating element is on. Yes, it should be hot enough when the light goes off. The numbers at the following site may not match but you should be able to find the information that you need.
Feb 18, 2014 | Toastmaster Kitchen Appliances - Others
I have a InStyler (the rotating iron) by Tre Milano. This device is for styling hair. This is not a flat iron, but a cylinder that warms up and rotate's against a brush. It has 3 heat settings which...
I'm repairing an Instyler right now.
Troubleshooting, I connected a multimeter and measure the voltage where the motor is connected. When I push the button that makes spin it, I measure 12Vdc which is a correct value for that motor. Then I connected the motor and it did not spin. Therefore I need to buy one motor here:
http://www.makepolo.com/products/Linear-Motor-with-4.5-to-24V-p39074920.html
Same motor... yes you can repair it by installing a new motor.
Feb 04, 2013 | Vacuums
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
Does this unit have an automatic cutoff in case it is left on by mistake?
No, this flat iron does not have a shut off feature. If you're looking for one that does, the InStyler has the shut off feature and it's one of the best I've had (plus it doesn't burn my hair as bad). Hope this helps! :]
May 24, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
English Instruction Manal for Tevion DBS2400 Steam Generator Iron
Hi. I am looking for an English Instruction Manual for Tevion DBS2400 Steam Generator Iron. Can anyone help please. Thanks very much Regards
Mar 21, 2010 | Irons
My rowenta leaks hot water
It is probably calsified (boiler stone has formed inside the steam ducts). Clean the iron according to the instruction manual.
If you have no manual, do this:
Heat the iron to the maximum in upright position with reservoir full of water. Turn the iron to 'operating position' i.e. in normal ironing position horizontally over a sink or similar. Use the extra steam button to force steam thru the iron. When the iron cools down so that the steam is no longer strong and some water is clearly leaking out, place the iron into upright position again.
When the iron is fully hot again, repeat the steaming. Do this until you have no water left. Let the iron cool down, add water and repeat the procedure until the iron doesn't leak anymore.
You will see the boiler stone coming out like hard dandruff. You can pull out bigger pieces with tweezers or similar. But be careful since the iron is hot!
Hope this helps. I do this roughly every month or two to keep the iron from leaking on my shirts.
Nov 26, 2009 | Cars & Trucks
Iron Manual
I need to know about the temperatures of the iron (what's hot & what's the cooler setting-rayon or linen).
May 23, 2008 | Irons
Health & Beauty Logo
146 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
