Question about Saeco Coffee Makers & Espresso Machines
How do I stop light flashing for shortage of water? I removed the water tank while machine was in operation
  • 17,130 Answers
Remove power plug and keep aside, Now attach the tank back and test after 1 hour so that it is reset.
Posted on Oct 02, 2010
I have a Rheem 40 gallon water heater the top element light is not operating at the exterior of the tank does this mean the element is out?
Could be the light is defective but if you are experiencing a shortage of hot water the top element may have failed.
Feb 03, 2016 | Rheem Water Heaters
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Air conditioner wont work
When the STOP indicator light turns on, the internal water tank has filled with condensed water and the air conditioner will turn off automatically. You can drain the internal water tank by removing the plug on the back of the unit, be ready for a lot of water to come out of the unit. The unit will shut down when the water pan is full. This condition may occur either when the unit is operated in high humidity conditions, or when the unit is being operated in HEATMODE, since the auto-evaporation function will not work in the heating mode. I hope this helps, have a great day, Andy K.
May 22, 2013 | Heating & Cooling
The led 27 flashing no stop
Hi
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jan 06, 2010 | Gaggia Syncrony Compact Digital Espresso...
All the lights are flashing on my Braun Tassimo TA1200 and will not make coffee
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Aug 07, 2009 | Braun Tassimo TA1200 Espresso Machine
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Jun 12, 2009 | Gaggia Syncrony Compact Coffee...
Water tank light is flashing with main heating light
HI
I don't think your machine is finished descaling. Follow these steps.
With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Apr 13, 2009 | Solis Palazzo Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Water light is flashing but tank is full
I had the same problem - Cause: plugged water filter. We always used RO water so never replaced the filter. After 4 years I guess it was due.
Solution: Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
126 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
