Question about Hitachi NT32AES 1-1/4" 18-Gauge Brad Nailer
Pulled it apart and it basically all fell out. need to find out what goes where? any help would be great!
    Master:
  • 343 Answers
The literature that came with it has exploded views of all parts. try Hitachi.com for a parts diagram, way too involved to explain here but I could re assemble it in 5 minutes if you were here...
Posted on Oct 02, 2010
My Mercedes roadmice USB fell apart. Can I get a new one that can be paired with the mouse?
if you have a usb driven mouse , then any will do as a new driver will be sought when you plug it in
Aug 20, 2016 | Computers & Internet
Dayton 3 speed switch 34g191 has no wires or diagram. how do I hook it up.
2a5da9a5-aac3-42c6-abd8-aafc5120b40f.jpg205419c3-0ab0-44b2-af3d-75ca1d7c5061.jpg30a6a9a2-5d9a-485b-aa23-85f37da6902a.jpgDayton fan motor 6C539A Grainger switch number 34G191. Luckly I have two fans. So when the one I went to pull out fell apart before making anything I pulled the other one apart. Okay, on the white plastic there are numbers l(1), ll(2), lll(3). Orange wire l(1), nothing in ll(2), blue wire lll(3). Now on the black plastic, the outlet wires go here: black wire L, white outlet is 180degrees (by orange wire) NEUTRAL SPLICER. Now, white wire from motor goes into the other side of the NEUTRAL SPLICER next to the black wire on the black plastic. This is just above the ll(2) on the white plastic. REMEMBER - NOTHING GOES INTO THE ll(2) ON THE WHITE PLASTIC.
May 02, 2013 | Dryers
Window fell inside door took panel apart and the cables are disconnected .... need instructions on how to put it back together with pictures if possible
That is basically not a fixable item, you need to replace the window regulator. Most of the time they will have the option to come with the motor. Even though it probably still works, I would recommend replacing it as a unit as the motor may fail before the new regulator goes out.
Jun 21, 2011 | 2003 GMC Sierra
So basically my left earbud doesnt work anymore, I dont get how this is possible, I bought them two weeks, one day I go use and its not working anymore, the right one works perfectly fine, i really need...
First try them in a different device,
if they still don't work properly - Your headphones are broken.
This can occur if they are pulled too hard - the slim guage wires that they use in these things can come apart pretty simply. My advice is to take them back and get new ones :)
May 11, 2011 | JVC HA-F120 Consumer Headphones
My Avaya/lucent 8410D phone got knocked off the wall and fell apart. I got it all back together except the hangup plunger wire/spring. Does anyone know the proper orientation of the wire to the plunger?
Hi,talking from experience,i will suggest you contact phone engineer in your area to carry out a check on the major components of your phone such as the earpiece,mouthpiece,LCD etc which might have been damaged(70%probability) as a result of the great shock experienced when it fell apart,
It won't cost me anything to give you the proper orientation of the hangup plunger wire,but you not knowing the orientation of this wire,which if i describe to you,you may end up doing it wrongly which poses a great risk or electric shock according to avaya,how are you sure some basic components have been installed properly by you.
So please take caution,contact a phone engineer in your area to assist you
Thanks and take care
Apr 09, 2010 | Avaya Definity 8410D Corded Phone
When I pull the starter cord there is no tension. The cord basically falls out of the weed eater. I pulled it apart and it will work for about one pull and not a second. When I took it apart a very small...
Ouch. It sounds like the cord rewind spring has gotten out of position. These things can be holy terrors to get back in the cavity in which they rest.
Check on a new rewind spring assembly. This might be more cost effective than trying to get a service person to put the spring back into place.
Oct 18, 2009 | Husqvarna Forest & Garden 125c 17"...
My rotating polarizing filter fell apart and I can
Based on the fundamentals of retaining rings, The filter lens probably fits into the ring housing first, and the retainer ring is inserted inside of the ring, following the lens. The retainer will need to be compressed in order to fit inside the ring, but will snap into a groove once in proper position.
I hope this is helpful... Good luck.
Oct 09, 2009 | Hoya 77mm Circular Polarizing Pro 1...
A/C unit fell out window, pulled out wiring
You should have two terminals marked L1 L2 That is wherer the two power wires go. The green is connected to ground. Rsuty
Jun 04, 2009 | Sharp AF-S80FX 8,000 BTU Comfort Touch Air...
Replacing heating element in oven-connecting wires fell back in
hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
Jan 02, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Hitachi NT32AES 1-1/4" 18-Gauge Brad Nailer  Logo
74 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
bwbconstruct
Level 1 Expert
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
