Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
When I copy a program's shortcut to the Maxtor 4 does that mean I will be able to put it on any other PC & use it?
  • 734 Answers
Only if the program is installed on the other PC and has been updated to exactly the same point and is also exactly supprted with all the hidden background runners like Java, Silverlight, .Net Frameowrk....ad infinitum.
It may operate, but if it does not, it's because shortcuts are tied not just to a program, but to all support associated.
Posted on Oct 02, 2010
Tip
Multiple G-talks
<span>MULTIPLE GOOGLE TALK IS POSSIBLE BY RUNNING THE GTALK WITH A SWITHCH CALLED /nomutex<br />THE FOLLOWING IS THE PROCEDURE FOR PUTTING THE SWITHCH TO THE SHORTCUT ICON:-<br />To edit existing Google Talk shortcut:<br />1)Right click on the Google Talk shortcut.<br />2)On the right click contextual menu, click on Properties.<br />3)Go to Shortcut tab on Google Talk Properties window.<br />4)On the Target textbox, add in the /nomutex to the end of the line so that it looks like below (or you can simply copy and paste the below syntax and replace the original).<br />"c:\program files\google\google talk\googletalk.exe" /nomutex<br />5)Click on OK.<br /><br />To create a new shortcut for Google Talk:<br />1)Right-click on the desktop or anywhere you want to place the GTalk shortcut.<br />2)Select New on the right click context menu.<br />3)Then select Shortcut.<br />4)Copy and paste the following line to the text box when prompted to type the location of the item:<br />"c:\program files\google\google talk\googletalk.exe" /nomutex<br />5)Click on Next.<br />6)Give the shortcut a proper name such as Google Talk or Google Talk Multiple or Google Talk Polygamy.<br />7)Click OK until you are done</span>
on Apr 04, 2011 | Computers & Internet
Tip
Maxtor OneTouch 4 Mini overview
MAXTOR MANAGER & SAFETY DRILL SOFTWARE - Clarification
(Please also see tip 'PC RECOVERY & MAXTOR ONETOUCH 4 MINI SOFTWARE' for some more details about managing this invaluable, but problematic, software).
1.) The CD Included with OneTouch 4 Mini
- is only used as a boot disc for system restoration using 'Safety Drill' copies of a whole system
(see 5. and 6. below).
n.b. Maxtor Manager and drivers are not on this CD
2.) Maxtor Manager
- When the drive is new, the installation files for Maxtor Manager (a set of utilies), as well as a comprehensive User Manual, are pre-saved as files on the drive itself. This is why the manual strongly recommends copying and saving them on the PC for future use. This is just in case you need to format the drive and then cannot retrieve the files to reinstall the Manager program later.
3.) Using the OneTouch 4 Mini without extra software
PCs already have the necessary drivers to run external drives so OneTouch can be accessed though its icon in the 'My Computer' window without any other software being required, and files can be copied and 'dragged out' or 'dropped in' as usual.
4.) Installation of Maxtor Manager
- Installation just requires double clicking on the 'Launch' icon, which is among the file icons on the drive itself
This takes you through the installation steps to install 'Maxtor Manager' on the PC.
5.) 'Safety Drill' Copies
- These are copies of the whole system in its current state, which may be saved onto the OneTouch drive by using the 'Safety Drill' utility, which is only one of the programs in the set of utilities accessed through Maxtor Manager.
6.) Using 'Safety Drill'
- To use it to make a copy, first install Manager and run it, then click on the Safety Drill icon in the row of utility icons across the top of each page.
In the event of a disaster, full recovery to the date of the last or an earlier Safety Drill copy can be achieved.
This is done by putting the supplied CD in the PC's drive, ensuring that BIOS is set to 'boot from CD' (the default), connecting the drive, restarting the PC to boot from the CD (see 1. above), and following the on-screen instructions to restore from a Safety Drill copy which has been saved on the OneTouch drive.
7.) If Maxtor Manager becomes corrupt
- e.g if Manager ceases to recognise the drive, or if the list of safety drill copies contains duplicates, it is time to uninstall and then reinstall it, which usually puts things right. But see 2.) if you should wish to format the drive as well, make sure you have saved a copy of these installation files from the drive :-
8.) Diagnose or repair disk errors, & check warranty status
- Seatools
is a free diagnostic, repair, and auto-warranty checker program which can be downloaded from Seagate.
9.) To preserve the Setup Files
Installation of Maxtor Manager is performed by clicking the file marked 'Launch' which can be found amongst the setup files on the OneTouch drive itself, see 2. above. They are not on the CD which is provided.
The files can more easily be identified at first by exploring the OneTouch drive, where they remain unless the drive is formatted. It is a good idea to copy the setup files to PC because no download is available.
on Dec 12, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Keyboard shortcut keys
By default, the shortcut key for paste is "Cntrl + V", where copy is Cntrl C, and cut is Cntrl X.
If you'd like to program a shortcut key for a program, say, notepad.. Find the notepad icon you use to launch it, right click, properties, Shortcut, shortcut key.
Jun 14, 2013 | Lenovo Computers & Internet
I want to change what a key types e.g. the numeral 2 key has the @ sign but you need to use the ctrl key to get it. I want to use the shift key to get it.
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
also
http://www.snapfiles.com/get/mapkeyboard.html
freeware
MapKeyboard enables you to remap your keyboard and alter any key to function as a different one or optionally disable it as well.
The program can be quite useful for laptop users and people with keyboards that differ from the standard
hope this helps
Aug 22, 2012 | HP Computers & Internet
Tip
MAXTOR MANAGER & SOFTWARE MANAGEMENT
These notes are offered because the software is problematic after the Maxtor Manager has been used a few times. But if you can get round its foibles it can be absolutely invaluable, being much quicker and more convenient as a rescue system than anything else I have come across.
The comments are based on trial and error with 80GB and 320GB versions which saved two installations on Win XP with a custom built PC, and one(so far!) on Vista with an Acer Aspire 5920 laptop, when clean installs from scratch would otherwise have been required.
The laptop had no Windows CDs and relied on serial backups on a second partition on the hard drive, as well as on two post installation backup DVDs, and sets of three and five other backup DVDs which were made later over two years. Life was too short to make another set for six months or so but luckily I got the OneTouch 4 Mini a few weeks ago, which saved the day when the serial backup system subsequently failed completely.
2.) Maxtor Manager
- When the drive is new, the installation files for Maxtor Manager (a set of utilies), as well as a comprehensive User Manual,are pre-saved as files on the drive itself. This is why the manual strongly recommends copying and saving them on the PC for future use. This is just in case you need to format the drive and then cannot retrieve the files to reinstall the Manager program later.
-PCs already have the necessary drivers to run external drives including OneTouch. When it is first plugged in the PC installs the drivers automatically so it can be accessed though its icon in the 'My Computer' window without any need for other drivers, and files can be copied and 'dragged out' or 'dropped in' as usual. However if Maxtor Manager cannot see OneTouch re-installation of drivers or Maxtor manager could be needed, see 8.).
-At first you can agree to this when it is offered automatically when you connect the drive.
- Later, re-installation just requires double clicking on the 'Launch' icon, which is among the file icons on the drive itself, when the drivers may, or may not, still be intact.
-These are copies of the whole system in its current state, which may be saved onto the OneTouch drive by using the 'Safety Drill' utility,which is only one of the programs in the set of utilities accessed through Maxtor Manager.
- Depending on the remaining capacity, the software may not like allowing less than 100% of the Drive for safety Drill copies and/or tends to fail to save properly if the percentage is changed. e.g. if 80% is already in use for other files and previous Safety Drill copies, and you want to save another copy there may not be room unless 100% is allocated for copies.
When the drive fills up it is unknown whether the automatic deletion of unmarked (for protection) copies works properly, or not.
-To use it to make a copy, first install Manager and run it, then click on the Safety Drill icon in the row of utility icons across the top of each page.
- In the event of a disaster, full recovery of the full working system to the date of the last or an earlier Safety Drill copy can be achieved.
- This is done by putting the supplied CD in the PC's drive, ensuring that BIOS is set to 'boot from CD' (the default),connecting the drive, restarting the PC to boot from the CD (see 1.above), and following the on-screen instructions to restore from a Safety Drill copy which has been saved on the OneTouch drive.
- The process is simple and progress is documented by clear comments on screen.
- After removing the CD when prompted, the System should be restarted without recourse to the BIOS to reset the boot priority, which should be only be done later once everything has been restored.
-e.g. if Manager ceases to recognise the drive, or if the list of Safety Drill copies contains duplicates, or shows other anomalies, it is time to uninstall and then reinstall it, which usually puts things right.Also see 8.) below, and if you should wish to format the drive as well, see 2.) and make sure you have saved a copy of these installation files from the drive :-
8.) If the OneTouch does not appear
in My Computer
or cannot be found by Maxtor Manager, right click on My Computer icon and select Properties, Device Manager, Disc drives, and expand Disc Drives. There will probably be a yellow overlay over Maxtor drive, to show it has a problem, so right click on it and select 'Choose drivers for this device' to reinstall them. Without going online they seem to be found somewhere locally on the PC to restore function.
9.) Diagnose or repair disk errors, & check warranty status
- Seatools
10.) To preserve the Setup Files
on Dec 12, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Safety Drill using the Maxtor OneTouch 4 Mini
The safety drill ONLY copies documents and email stuff. So the restoration process would only put back all the documents (and pictures) and email info. It should not interfere with the rest of your computer setup at all.
Jul 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
I have a Maxtor Mini 4 that has all my important info, I used it with my laptop (dell) that had Windows xp. Now I have an HP desktop with Vista. It recognizes the Maxtor but it is "unallocate" & it...
Your problem is that you have 2 different proprietary companie's hardware and they are incompatible with each other. You should reinstall the Maxtor Mini 4 and copy the Data to a cd or dvd, or print all of the data to have hard copies of your Data. After you made hard copies of your Data, now you can re-enter all your Data into the new HP system.
Aug 30, 2017 | Seagate 80GB One Touch 4 Mini-maxtor USB...
My desktop shortcuts open with search results page only
1.
Right-click Start, and then click Explore.
2.
Locate the folder, file, or program in the Folders directory, and then click the item to open it.
3.
Click the icon representing the item.
4.
Click File on the toolbar, and then Create Shortcut on the drop-down menu that appears.
5.
Right-click on the shortcut icon that is created.
6.
Choose Send To from the drop-down menu, and then click Desktop (create shortcut) on the submenu that appears.
Jan 09, 2009 | Acer Aspire™ T180 PC Desktop
How to create a desktop shortcut for yahoo mail?
Go to Yahoo! Mail page. At the top of your screen click File, a menu drops down, put your mouse cursor on Send, a menu pops up, click Shortcut to Desktop.
Another way is go to Yahoo! Mail page, right click, a menu pops up, click Create Shortcut, a pop up asks "Do you want to put a shortcut to this website on your desktop", click Yes.
Nov 15, 2008 | Yahoo Mail
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
