Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Replacement parts... I've got a 3594 Bissell and the belt has come completely off. In the process of breaking, it bent the metal guide inside the motor housing and melted the plastic that holds the guide and keeps the belt inline with the roller. I've got it running again by using a screw I filed all the threads off of, but it only works for 10 minutes at a time before breaking another belt. This process is getting expensive, as it usually takes 30 minutes to completely vacuum the house. Is there an exploded view of the parts and materials somewhere? Bissells site is no help. It's only got standard replacement stuff and I think I need to replace the whole motor housing. Unless someone here has a fix.
  • Bayouwolf May 27, 2008
    Thanks a ton...
    I really like this vacuum and it would be a shame to replace it over $30 part.
    Out of curiosity, where did you pull the part number off of? I searched for hours with no luck before finding this site.....
    Again, thanks.
  • 1,673 Answers
Most likely it is the top cover that needs to be replaced, part #2031238 and is around $30. It would have that guide on it.
Posted on May 26, 2008
  • Lauren Junge
    Lauren Junge May 28, 2008
    Can't tell, I have my sources, but glad I could help you out.
How do i change the belt on my bissell powertrak
Give this a try.
Sep 05, 2010 | Bissell 3594 CleanView PowerTrak Bagless...
Brush bar wont turn, Bissell smells like burning rubber
The belt just goes from the motor shaft to the brush roll. Do the ends of the brush trun freely, or is one of them froze up, if so replace the brush roll. If it is ok, try to turn the brush roll by hand, maybe the belt got pinched and won't move.
Aug 25, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissel 3594-1 release lever
Flip over the vac and use a long skinny screwdriver to spread the tabs that capture the two nubs on either side of the lever then pull the old part out. Then simply align the new part, and press it down into the slot till it clicks in place.
Jul 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell revolution roller won't turn
Did you check the brush roll, if one of the ends is melted together and won't turn, then the belt will just slip and overheat.
Jul 12, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
Mar 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell vacuum problem
the motor as a cut out switch ,if the motor housing is full of dust , the motor will get hot and the switch will activate ,
Nov 20, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Roller and belt changing need schematics
How to change the belt on the Bissell Clearview?
Sep 02, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
122 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
