Question about Car Audio & Video
Mitsubishi car alarm grandis
Plip buton wont open vehicle.When you open it with key the alarm goes off,can i switch off alarm,to drive it to a dealer
ginko
  • 19396 Answers
SOURCE: car alarm preventing car from starting
Try removing the alarm system relay, some car alarm has also a fuse on the alarm that you can remove.
Many car alarms unlock by inserting and turning car key while you connect the battery.
Posted on Aug 19, 2008
lnwolf33
  • 14 Answers
SOURCE: cannot disable anti theft alarm driving neighbours mad
There should be a relay under the hood for the security system, if you can not find it, try jacking the front of the car up, it should have a sensor that tells it that it is being towed and should turn off, unless of course it has a bad wire that is grounding out.
Posted on Jan 28, 2009
SOURCE: Key Fob does not work and alarm goes off when raining
the central locking control unit is in the drivers door. there's a polythene sheet in the door panel. If that's ripped or petrified then rain may be screwing with the electrics. it may be worth taking off the door panel and wrapping it the controll unit in a shopping bag or summat.....
Posted on Jun 05, 2009
  • 67 Answers
SOURCE: car alarm randomly goes off
there is a hood switch located at front passenger side under hood. check to make sure the plunger at hood is pushing the switch completely down. sometimes there may be just enough clearance that a strong wind will set the alarm off.
Posted on Jul 20, 2009
  • 61 Answers
SOURCE: my Mitsubishi Chariot Grandis GDI, V6 Royal N86W
205 is the width in mm. 65 is the hight of the sidewall (.65x205=133.25mm)65 percent of the with. 15 is the diamater in inches of the rim (tire hole) for example if you keep the same rims 205 75 15 would be the same width but slightly taller.
215 65 15 is wider and taller as 65% of 215 is 139.75 millimeters. if you go to 16 or 17 inch rims u can get much bigger. the width of the tire must not rub on the insides of the fenders. the hight must not contact the top of fender taking in consideration the suspension. u can look for car clubs of that model and chat with the members.
Posted on Jul 23, 2009
The alarm keeps going off everytime a car goes by but you try grabbing the handle and shake the car nothing happen on a Mitsubishi Grandis 2004
It is probably a glass vibration sensor being triggered by the street noise rather than a mercury switch that would be used if you shake the car. The vibration frequency is much higher for street noise than for a simple shaking of the vehicle.
Jul 31, 2016 | Mitsubishi Cars & Trucks
95 lebaron convertible chrysler alarm goes off when opening door with key
If it is an OE, original equipment, alarm it would be necessary to discover exactly how the alarm is armed and how it is supposed to be disarmed. The vehicle handbook might help.
Generally such systems will sound the alarm if the car is unlocked with a key if the remote or plip has been used to lock it.
Aftermarket alarms are notoriously unreliable and short-lived unless expensive and are usually badly fitted. Often the best thing is to remove them and recycle them.
A local auto locksmith might be helpful.
Jun 21, 2016 | Standard Fuel Pressure Regulator 1991-1995...
Alarm is not resetting tried to reset using suggestions on the forum no success
does the car lock and unlock with the plip? if so you may have a problem with the pats. security system. and will need to go on to suitable diagnostic equipment to sort it out, if it does not check the plip battery and try to reprogramme by switching the ignition on and off 5 or 6 times until you hear a chime, remove the key and press any button on the plip you should hear the chime again to confirm the operation.press any button on your spare plip if you have one or you will loose that plips programme and will have to repeat the operation. these plips are unreliable, they suffer from static electicity interferance. there is a simple mod availiable from your jaguar dealer to rectify that problem, good luck,
Mar 31, 2015 | 2002 Jaguar X-Type
Alarm keeps going, car locked or unlocked
Hopely this trick is useful.
1. Open the window.
2. Disconnect the battery.
3. Close the door. (Keep the window open)
4. Turn the ignition key on.
5. Find the hood sensor in engine bay area. (It looks like push button)
6. Press the hood sensor and reconnect the battery. (Keep pressing the sensor)
7. Ask someone to start the engine (Keep pressing the sensor)
8. After the engine start, you can release that sensor.
9. Now your alarm vehicle was deactivated.
This trick is effective for common mitsubishi car which not using immobilizer.
Mar 08, 2015 | 2006 Mitsubishi Grandis 2.0
Will I be able to start and use my car if the key fob/plip isnt working?
everything should be ok as long as u got the key to start the car
Jul 07, 2014 | 1999 Renault Megane
Peugeot 406 key fob not operating central locking
406 FOB / PLIP PROGRAMMING :
The 406 deadlocking remote control has specific button controls, and if the vehicle has two controls, one is set as primary and the other as secondary.
When replacing the Plip, a Primary or Secondary Plip are different part numbers and must be ordered as required. The white label inside the Plip is labelled PRIM or SEC.
1. Turn the Ignition switch ON.
2. Press the large Plip key button (Primary Plip)
3. Within 10 seconds press the large Plip key button (Secondary Plip)
4. If there is one remote, press the Primary plip button twice.
5. Turn ignition OFF.
6. Test Plip's for correct operation.
NOTE : On some 406 models, Plips cannot be re-synchronised unless the battery has been disconnected for 1 minute
Oct 27, 2012 | Cars & Trucks
Alarm will not stop sounding off...Truck wont start...Alarm will not disable...Doors will not unlock...Everytime I open the door from inside or outside alarms immediately begins and won"t...
make sure that the the remote's battery is still good otherwise it wont activate your vehicle but if it is equipped with an alarm ( your car), then possibly alarm stays on everytime you open your door with the key which has no chip in it. go get new battery for your remote.
Jan 15, 2011 | 2008 Chrysler Aspen
How do you reset the key fob on an old peugeot 405.. 1 button type
There are 2 types, IR that has a little bulb next to key and rf. IR type
1. Turn the Ignition switch to the accessory position using the key without the remote plip attached.
2. Hold the Plip key close to the central locking receiver mounted in the roof console.
3. Press the large plip button and then the small plip button on the remote.
4. Repeat for second Plip key if required.
5. Turn the ignition OFF.
6. After 5 seconds the Plip should now operate.
RF type
1.Switch off the ignition
2. Switch on the ignition
3. Immediately after switching on the ignition, press the large remote button
4. The remote should now be working again.
Jan 07, 2011 | 2005 Peugeot 405
I have a 2006 Mitsubishi Grandis. Something weird is going on. The alarm doesn't activate/deactivate. When I turn on the ignition key to accessory, nothing happens. The internal lights do not work. ...
It may start the engine fine, meaning it has a good ground, BUT, the ground from battery to the body is NOT. Make sure that connection is good and clean.
May 12, 2017 | Mitsubishi Passenger Cars & Trucks
Car Audio & Video Logo
151 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
