Question about Toshiba 27A43 27" TV
How do i program channels without remote control
  • 130 Answers
Hi
sorry no way !!!
Posted on Oct 02, 2010
Programming a TV without remote
You must have its remote control to program this TV.
Feb 17, 2013 | Televison & Video
I have a Sony Trinitron model KV27S35, but no remote. How do I program the tv without the remote?
The SETUP button on the case accesses the menu.
Press Channel +   to select Language.
Press Volume -    - now the tv will be reset to factory condition.
Press Channel + to start the AUTO PROGRAM and wait for it to finish.
Press Channel -  to exit it.
That is all. If you need more then all the menu options can be accessed thru the key on the tv.
Aug 17, 2010 | Zenith ZN110 Remote Control
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Correct code for Magnavox TV modelMMC24T5A not on code list
If code is not on list do auto search for the code.
Automatic Programming
With automatic programming, the remote control tests all the codes available
on the Code List and assigns the correct code for the selected device.
Although this method can be more time-consuming, it eliminates the need to
look up codes and enter them manually.
1. T urn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode.
3. Press and release . The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL + or CHANNEL - after the device turns on.
6. Press any other button. If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
Good Luck and Please Rate FixYa!
Dec 27, 2008 | Brookstone 538744 Remote Control
I have a philips pm335 universal remote control
I went to the Phillips website and I wasn't able to find a code list. However, I did find the instructions to program your remote with "code search". Basically, it might take some time, but you can program your remote without the code list.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 26, 2008 | Philips Universal PH301S Remote Control
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Programing
Hope this helps :)
Jun 09, 2008 | Philips Universal PH301S Remote Control
Remote code
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Programming channels
Not knowing what TV you're talking about it's hard to say. Can we get a model number on the unit?
Dec 07, 2007 | Televison & Video
Toshiba 27A43 27" TV Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
