Question about Plumbing
I have a leaking shower that I cannot stop. I have put in a nylon (plastic) seat set, that didn't work. I put in a stainless steel seat set and that still didn't work because the o ring came out from behind the seat set. How do I get the thing to stop leaking without taking the hole thing out of the wall?
    Problem Solver:
  • 77 Answers
This may be a dumb answer but did you use Teflon tape on the threads.
Posted on Oct 02, 2010
I need a shower curtain rod that won't rust/corrode
For rods that won't rust you might need a rod made of stainless steel or even nylon. This site sells these type of shower rods:
http://www.showerrods.com/
Nov 30, 2012 | Home
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
Why is my coffeemaker leaking from the bottom?
  1. Make sure the filter is properly in position and that the brew basket is fully closed.
  2. If the coffeemaker is equipped with a removable water reservoir ensure that the reservoir is properly installed.
  3. Avoid overfilling the water reservoir. The coffeemaker is equipped with an overflow slot near the top of the water reservoir. If too much water is added it will flow out of this slot and collect near the base of the unit.
  4. The coffeemaker may require service. Contact an Authorized Service Center.
Sep 21, 2011 | Philips Senseo HD-7810 Coffee Maker
Need window in lid of Back to Basics popcorn poper, about 15 years old
Melanie322 - you wanna sell me your other window? :-)
Apparently West Bend bought all that company, and they do not list a replacement plastic window.
The plastic window on my stainless steel stovetop popper broke right under the middle screw, so I went to the hardware store and got a big nylon washer and put it under the screw. It ain't pretty, but it hold the little window up...
Jun 29, 2010 | Back to Basics 6112304 Popcorn Maker
Our coffeemaker leaks water from the bottom while brewing
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 17, 2010 | DeLonghi BCO120T Programmable Espresso /...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
