Question about Shop Vac Vacuums
We have a series 90S, 2.5 gallon Shop Vac. We used it for the first time to try and **** up water in the basement. Each time we turned it on, it would shut down after collecting less than 1" of water. We had to remove and squeeze out the foam sleeve each time, before it would work again (nowhere near 2.5 gallons!). Any ideas? Is the plastic sleeve that can move up and down inside, the float (poorest manual I've ever seen!)? Should there be a ball float that we're missing? Thanks for any suggestions.
  • stonebri Oct 02, 2010
    Pwillitz: A follow-up question please. Should the cup-shaped float have the open end at the top, or pointing down to the bottom of the unit? Reading other questions/answers here, one of the Guru's answered a question about this by saying "It goes in with the open end facing up". If that's true, then our 'cup/float' was installed backwards -- as the open end faces the floor!
  • 377 Answers
Remove the foam sleeve when using the unit to pick up water. The float is in there to indicate when the unit has "enough" water in it. The float rises with the amount of water and when the water reaches a certain height the float is "pulled" up into the air exhaust hole causing a change in the sound of the unit. This is the audio indicator that it is time to empty the water. If the foam gets wet with water, it closes off the air almost like the float does and the suction of the unit is reduced.
Posted on Oct 02, 2010
Testimonial: "Thanks so much for your very quick and helpful response!"
  • 11 more comments
  • pwillitz Oct 02, 2010
    Not sure of the physical shape of this, but it should be installed so that it floats on the water and the convex portion can shut off the air port and stop the water from getting to the motor.
    The older models had solid balls in them to do this job.
    This is my hypothesis without having looked at the unit.
    Parts blow up can be found here:
    http://www.shopvac.com/pdf/parts-lists/8...
    Hard to tell from what I see, but I believe the cup would be in upside down so that water could not fill it and cause it to stay down. It would ride on top of the water due to the air pocket created.
    Make sense?
    Pwiilltz: Yes, I think that makes sense. Unless we can open it (it's not in front of me now), then the float was put in upside down at the factory...preventing the cup/float from rising. Thanks again for your help!
    Just wanted to be sure you understood my comment.
    I believe the correct installation is with the open end down. In this form the air will be trapped inside of the cup and force the cup up so that it will shut the air off (sound of motor changes) when the unit is full of water.
    If the open end were up, it could fill with water and stay down.
    My opinion, your unit was installed correctly when built.
    THANK YOU very much for the rating.
    Are you on the east coast by chance?
    Stay dry!
    Thanks for the clarification. I did misunderstand you and thought you were agreeing with the other 'Guru'. :-) We'll try your first suggestion...to remove the foam sleeve when picking up water... although in our manual under 'Wet Pick Up Operation", it says: "Wet pick-up requires the foam sleeve to be in position over the lid cage." So, I'm still a bit confused!
    Thanks.
    I don't mean to beat this to death, but I do find the problem interesting.
    When the vacuum sucks the air/water, at some point it becomes easier to lift the weight of the float and shut the pulling power of the vacuum down as the tank fills with water.
    As the foam gets saturated(?) with water, the same thing occurs and the float is lifted.
    It seems the foam is getting too wet and the pulling power of the vacuum will lift the lighter weight of the float and shut the pulling power down.
    I guess the real question is why is the foam getting so wet so fast?
    Is it the correct foam filter?
    I have two units that do not use any type of filter when lifting water. Perhaps the foam filter does act to keep any debris that might be found in the water from getting into the impeller/fan.
    Just a thought.
  • stonebri Oct 03, 2010
    Thanks much again for taking the time to share your knowledge. I don't know why the manual says to use the foam sleeve for wet pick-up, but then it's not much of a manual! :-) We'll give your suggestion a try next time it rains and we have water in the basement!
  • pwillitz Oct 03, 2010
    Did you lower my rating because I asked too many questions?
    You've got it....Allentown, PA! 8.2 inches at the airport.
    Although my wife purchased the machine 8 or 10 months ago, this was the first time she used it. So, the foam was what was in the original box.
    I couldn't seem to reply to your last post, below. New to the site, I didn't mean to lower your rating! I've hopefully corrected it now!
    Although my wife purchased the machine almost a year ago, this was her first use of it...so the foam was original to the box.
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
I have a 10 gallon Shop.Vac 3.0 but I don't have the instruction booklet. Do I take off the pleated "paper" filter to vacuum up water? Do I use the vac with no filter for liquid?
Yes you should remove the filter for liquids. If the filter is not removed the internal float stop will not operate correctly. This will lead to the liquid being drawn up into the impeller and around the motor.
However I still like to have something in place because in most instances the liquid you vacuum up will not be without some solids. So I like to use a foam insert. Places like Home Depot carries a universal insert that works great.
Hope that helps.
Sep 17, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
Jul 08, 2009 | Shop Vac 962-16-00 Ultra Pro Canister...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Over heating?
it sounds like you need to replace the motor in it . thank you for using fixya
Jun 19, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
468 people viewed this question
Top Shop Vac Vacuums Experts
Jim Parker
Jim Parker
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
