Question about Garmin zumo 550 GPS Receiver
My garmin zumo will not turn on.
After a few months of disuse, th unit will not turn on despite charging. No response from any button
  • 11 more comments
  • annjim Jun 01, 2008
    It worked perfectly when last used 2 days ago I have been downloading quite a number of map routes from map source for my vacation on a motorbike. When I went to download a further last minute route I discovered no power from either the USB connection for mains. I have tried resetting by holding the + and power on buttons, removing the battery for several minutes all to no avail.
    Any suggestions I go on vacation Tuesday morning it is now Sunday evening, other than spending more money on another unit. This Garmin zumo 550 is only 12 months old but has only been used approximately 6 times.
    Thanks
  • Anonymous Jun 24, 2008
    Still worked fine yesterday Zumo 550 BMW edition - today when I really needed it - dead as a doornail - no response even after prolonged pressing of the power button :(
  • Anonymous Jul 08, 2008
    I have also had this problem with the ZUMO 550 not turning on. I have removed the btry and replaced it in the pass and that worked. This time it does not seem to be doing the trick.
  • bedouin_tr Aug 02, 2008
    I also faced the same problem. In the morning it was working without problem, but in the afternoon could not turn my 6 months old Zumo on. Even though I tried to reset it, does not respond to any button. After I remove the btry, the problem solved ;)
  • Anonymous Aug 16, 2008
    I am having the same problem; ie sometimes its totally dead. After it sits for a while (with the bike on a battery tender). It eventually comes back to life. It may be a coincidence but the problem started after I turned up the brightness on the screen so maybe that is causing battery drain. I also notice sometimes it doesn't shut off as it should when the bike is turned off, and sometimes it turns on by itself for no reason.
  • zcubrc Aug 23, 2008
    This is my 2nd Zumo 550 with the exact same problem. 1st one went dead after a month and had to return to PC Nation. The 2nd one (a refurbished one against my will, I don't recommend PC Nation!!) is now dead after 6 months after using just 2 hours ago. What is up? Does anyone know how to fix this?
  • Anonymous Nov 06, 2008
    Blimey - me too! Mine switches on for 5 seconds or so and then blank. I've tried taking out the battery briefly but to no avail.
  • Anonymous Dec 08, 2008
    used it to find a wendeys and after i was done i got back in my car and it wouldn't turm on!
  • hmartin862 Jan 05, 2009
    same thing here no power at all, tried the battery removal (bought new one) will not power up or be recognized when hooked to computer , waiting to hear back from garmin
  • chuck44_wrig Feb 19, 2009
    same thing here no power at all, tryed the reset, charging battery, removing battery, have emiled Garmin waiting for reply.
  • Anonymous Mar 26, 2009
    ny garnyb had the same problem is dead
  • Anonymous Apr 06, 2009
    I had the same problem and I  took the battery out and put it on the bike mount without the battery installed and the Zumo finally turned on. I put the battery back in and now it seems to be working ok. Solution#3 worked for me thanks you are a GENIUS!!!!
  • mafgent6 Apr 07, 2009
    I install my motorcycle bracket and install the zumo 550 in it work the first time then didn't want to turn on I removed the battery and replace it and now it is working but the battery would not take any charge at all 18hrs and still say low battery. It is a brand new unit 1 week old .
    Scholar:
  • 174 Answers
Have you also held the power on button for a couple of minutes, with the battery installed, and without the battery installed. There is an issue with the garmin dying, some cases a new battery helps, other cases, just leave the battery to charge for several hours, worst case is that you have to ship it to Garmin. I had a couple of Dead Zumo, however, removing the battery for several minutes, putting it back and clipping the zumo in the car holder did the trick for me. I also have a spare battery and allen wrench, just in case...
Posted on Jun 10, 2008
My Zumo 550 went dead while riding. Simply removing and replacing the battery was enough to bring it back to life.
Posted on Jun 30, 2008
I had the same problem and by connecting the Garmin to a computer using the USB cable that comes with the device, you will be able to immediately get the power back. Leave it connected so that it can recharge the battery completely and it should be working fine afterwards. It happens sometimes when the battery is completely dead and so it needs to be connected to an electrical device to regain its optimal charge. I hope this can help!
Posted on Apr 07, 2010
I took the (fully charged) battery out, replaced it: still dead. Then I hooked it up to my computer (usb cable), and it immediately turned on and went into the 'mass storage mode' (as it should).
After disconnecting the Zumo (ejected the drive (Mac), then unplugged), it works again just like before it faked death.
I understand that you don't necessarily carry a computer everywhere you go, but on longer trips I carry an A/C power supply cord ('Garmin Switching Power Supply', model PSC05R-050A1). This should do to jump-start the Zumo,since it uses the same port on the device as the usb. I have yet to replicate the problem and confirm this method with this power supply.
This of course requires an electrical outlet you have to find and 'borrow' for a few seconds.
If you want to be even more independent, and your bike has a provision for a cigarette lighter style power outlet, get a 12V to 120V transformer: it's under $15, gives you a regular electric plug, and is really handy in a pinch.
Posted on Jan 24, 2010
If this becomes a recurring problem, but the battery removal fix works for you, you may want to take the battery mounting screw and cut a slot in the head. this will allow you to use a regular screwdriver instead of carrying around a special allen (hex) wrench/key. i put a tiny bit of wd-40 (lubricant) on the face of the screw in my unit, since cutting the slot takes off the anti corrosion finish.
Posted on Apr 19, 2009
Posted on Jun 16, 2008
I have a iron GC9600 where is the reset button on it
There is an on/off button. The iron turns itself off after disuse for a period of time. When it does so, it lights this button. The diagram to the buttons is a few pages earlier than page 6 which describes the behavior of this button. Notice there is no "reset" button in this list other that this on/off button. The user manual:
Philips GC9600 series Directions For Use Manual English
Aug 27, 2017 | Irons
Will not run on battery. charged battery but will not hold charge.
Hi Martha, had a bit of a look around and noticed a few mentions of charging problems including the following - 'One of these units was apparently dead on arrival and on further investigation, it worked off mains but not from battery. The battery comes out from a flap underneath the unit, and on testing with a multimeter, it was under voltage, so must have been old stock. Despite 2 days of charging, no life, so I ordered a replacement battery (RITAR RT1250 or equivalent 12v battery) and it works fine. I also have a proper battery charger rather than use this unit's own charger, which charges the battery rapidly, but I think at the cost of battery lifespan. Given that I use this unit infrequently, this is fine, otherwise use the internal charger as normal. With the new battery, I've never managed to run out of battery.. it will keep going all day on a single charge.
The manual does state that if you don't charge the unit at least every 6 months, it may not charge.'
I know it's not exactly a resolution but hope it helps!
Jun 16, 2015 | ION Audio Tailgater Portable Pa System For...
Mecablitz 45 ct 4Have an old 45ct4. Which functioned when last used. Have new cell in my QB2, but flash does not turn on, as if it's not getting power. Is there anything in he flash which would have...
The flash capacitor may need formatting after a long period of disuse (years). This means a longer than normal charge time and a few charge-discharge (test flash) cycle. If however the red LED, next to the power switch, does not light up after a few seconds, the flash can be faulty. Having repaired a flash of this age is not easy, spare parts are not available.
Feb 27, 2014 | Cameras
IPad button not working
iPad screen cracked a few months ago
its been acting faulty ever seance hav to turn it off to charge and now cant turn it off th butten is jamed any seluton?
Jan 01, 2014 | Apple Ipad I-pad
AVH-x5500bhs Crash?
Remove the car's negative battery terminal and let the car sit like that while you push that reset button again and hold it a few moments. Let it sit maybe 15 mins. Im thinking a static charge has built up and the unit needs to discharge. Reconnect the neg battery terminal and see what happens when you turn the unit on. Cold dry weather can allow static charges to build up.
Dec 05, 2013 | Pioneer Car Audio & Video
SanDisk Sansa Clip will not turn off. Screen lit, muSic info ShowS, no reSponSe to controlS including on-off button. Battery ShowS fully charged.
two things to try....
the first wil be to connect unit to PC using USB cable. let it sit for a few minutes then uplug and see if it resets itself.
If not (AND THIS ONE WILL ERASE YOUR DATA STORED ON UNIT!!)
there is a little inset reset button on unit, usually onback or bottom. use a papr clip to press in and hold for about 10 seconds.
This should also reset unit.
Hope this helps
Thanks
Please rate FIXYA
May 24, 2011 | Computers & Internet
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
How do you use the backlight on polar ft1?
While the time is being displayed, press and hold the button until the backlight turns on; it will automatically turn off after 5 seconds of inactivity. Thereafter it will turn on for 5 seconds every time the button is pressed. After 5 minutes of unit disuse the button's backlight feature will automatically deactivate.
Sep 23, 2010 | Polar F 6 Heart Rate Monitor, Coal
I bought a used Porsche with an Alpine IVA-W200 system already installed. The radio and CD player worked and I could hook up an MP3 player to a wire in the gloove compartment. The only problem was that the...
The expert I chatted with was both right and wrong: correct in that the problem was not the small battery in the handheld GPS unit (which feeds signal to the IVA-W200), but was incorrect in guessing the problem was due to a fuse.
I took the fuse out, it looked good, and put the same fuse back in. After that, everything works! Apparently, the IVA-W200 can freeze up (like a computer sometimes freezes) and it needed a cold start reboot. Removing the fuse completely for a few seconds (for examination) took power to the IVA unit down and back up again... voila'!
Dec 16, 2008 | GPS
Porta wattz 1750 inverter
turn the unit off and then disconnect the negative from the back and turn th unit back on that way the inverter will use all the charge kept inside.
Reconnect the negative and start the unit ...I did that to my unit and for fun I asked tech support for help they told me that I need to buy ne one...After I reset my unit I been using now since for over 2 years...sometime it come back one every few months if I have high voltage coming and I redo this again and it works...save your money
Oct 31, 2007 | Statpower PW-1750 Triple Outlet 1750 Watt...
Garmin zumo 550 GPS Receiver Logo
7,436 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
