Question about Samsung Televison & Video
I have an LCD TV- LA37R8, purchased about two years back, and hence out of guarantee period. Last week, I found that the power-suppy shown by the red light indicator was not responding either through remote or to the push switch right above the indicator. The screen "alive light" at the bottom, shining even when TV is switched off was also not showing. I called the local cusstomer service, @91-79-30308282 -complaint ref. no.8407609683 on 30.09.2010. A technician visited my place , opened the rear full panel of TV, and either he was not conversant with the circuits or mechanism, he just closed the rear cover saying that the TV requires replacement of some circuit boards which have got to be got from Delhi. The request to Dlehi wwould be made on 4th. and we might get the part in a week or so!! Please help me in his matter and send a knowledgeable Engineer and not one not even knowing English or technical terms!! Please do not send half-baked Technicians who might damage the TV by rough handling and not conversant with the circuits.
  • Samsung Master
  • 3,828 Answers
Todays TV repairers can only replace entire boards
the right question to ask is
does LCD as a company provide after sales parts for your TV
or their board circuitry information to TV repairers or the general public
you may find LCD have no parts support
TV makers only want sales of the new TV produced
otherwise an oscilloscope and lots of time is required to track down the faulty diode or capacitor or micro processor
Posted on Mar 06, 2017
SOURCE: Power Surge damage. Suggestions on which part to replace.
I would start looking at the power supply, it's usually a separate board where the a/c line plugs into. In many cases i have seen that the problem you described is from a damaged power supply, sounds like something is shorting causing the power supply to continuously come on and off. I would first check the capictors to see if any of them have blown, usually cylinder looking and sometimes you'll see an X or a K at the top of the cylinder, if it's blown then the top will be bulging out instead of being flat. If all those look good then there is probably a short somewhere else like in one of the transistors, if so you'd be best to just find another power supply board to replace.
Posted on Nov 09, 2007
  • 934 Answers
SOURCE: Red noise or flicker on bottom half a plasma screen
The old saying that a pictures is worth a thousand words could have been looking at this one... If the lower screen had been streaked in B&W or bands ran completely through the picture Old Drummer I would suspect the logic board also but that's lower y-board failure.
Posted on Nov 15, 2007
  • 261 Answers
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
It does sound a lot like a buffer board problem, Just which one is the question. Sometimes it is in fact a connection issue. But 1/2 of the screen missing sounds like maybe connection between the 2 buffer boards. It could possibly be the panel. If that is the case. ITs over for that set. But i would suggest first calling samsung and asking them to extend the warranty for 90 days or so. Sometimes they will do this for nice customer such as yourself. 1-800-SAMSUNG. Let me know how this turns out first then we can proceed further if needed. Good luck and keep me posted. Sincerely Jay
Posted on Jan 31, 2008
  • 2326 Answers
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to
Posted on Jun 08, 2009
  • 100 Answers
SOURCE: oven door locked, can't get plastic cover of control panel off
you have to first remove the side trim there should be some screws in the side usaly 2 but sometimes 4 ---you could have replaced just the fuse for less than 20 dollers
Posted on Aug 09, 2009
Samsung UN55C6500 turns off and on at random
ghosts. actually, check your house wiring, for leaks, open grounds, etc.
Feb 01, 2014 | Samsung UN55C6500 55 LCD 1080p HDTV LED...
The timer does not turn the TV to the right feed
If the TV timer is set within then it will restart in the same channel as when you connect the power to the timer the whole power is shut down and so the memory is lost on the last attempt. Hence the TV will start back on the default setting unless there is proper back up on the memory.Please check if the TV timer can be reset to solve this issue or the memory must be checked for fault to retain last settings.
Dec 14, 2011 | Samsung LN52C530 52" LCD TV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
I have a panasonic plasma th46pz80u. Last week
On Panasonic 32LX TVs this is a known fault, repairable by a firmware upgrade. John Lewis in the UK sent out an engineer under their free 5 yr TV guarantee and completed the firmware upgrade for me. The only other store to compare with them for price and service is Richer Sounds but I believe you now have to buy the warranty for 10% of the purchase price. This problem will persist unless the upgrade is completed. For those of you in the UK, I would insist the seller repairs the problem under the Sale of Goods and Services Act as the TV is not fit for purpose without the upgrade.
Dec 09, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Sharp Aquos 32 nch TV, turn TV on, come on & goes off withn 2 sec
You have an intermittent power supply issue. See if you can get a used one on the cheap.
Aug 23, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
Will Not Turn On
check PW suppy is ok check all voltages in the micro controller IC
Dec 05, 2007 | Televison & Video
Olevia 32" LCD TV
If you wish to get some details; visit the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 25, 2017 | iLO 3200 32 in. LCD Television
Protron 32" LCD TV
build your own buy a generic one and patch cables to it
Jun 23, 2007 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
