Question about Car Audio & Video
Video bokep ariel cut tari - Car Audio & Video
How do i install my tv.
Make sure the input is set to cable or antenna
Nov 29, 2017 | Televison & Video
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
I have a soniq tv and all of a sudden the picture just started cutting in and out, I thought it was the reception from the Ariel so I turned it off for a bit turned it back on and there was no picture
1. Check the connections for tightness on the input wires going into the TV. If this doesn't fix it, check that the cable going in connections are secure on the wire.
2. Check the connection outside on the ariel, this might have loosened or froze loose with ice and wind..
Jan 18, 2013 | Televison & Video
Ford fiesta 2003 radio not recieving any stations ariel is connected & have changed over roof ariel with no success still plays cd's
Have you checked the connection at the rear of the radio, it may have come out, you can see it if you unclip the glove box and look behind the radio with a torch.
Nov 03, 2009 | Car Audio & Video
I have a Dell Latitude D600 that went out this afternoon saying A Disk Read Error Occured Press CTRL + ALT + Delete to restatr and I do and nothing happens but the same statement occurs. So I removed the...
Dear Tari
the error is pointing towards hard disk failure, plz check the data cable, power cable. if you are not familiar with the hardware then you better ask some professional to help you out.
Dec 17, 2008 | Dell Latitude D600 Notebook
Ariel socket in tv has broken
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Oct 24, 2008 | Polaroid LCD-2050 20 in. Television
Car Audio & Video Logo
181 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
