Question about Kodak EasyShare Photo Printer 500
All in one printer kodak 5100
Go to print and in the middle a screen that says error please start over by shutting down happens every time and also takes a long time to print already upgraded with new kodak gallery disk which helps print a little faster but still get error whether on line or off please help gets frustrating after a while and feel i don't recommened this to anyone unless problem solved great pics but takes to long
  • wildly May 29, 2008
    please reply on this comment without having to pay for it what kind of help is this for us customers who need help. not fair for us to pay when we buy the product and have problems
  • 4,041 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
When requesting print from my wordpad, I get the response "printer not detected" Going into the maintenance program it says "congratulations the printer is fixed " but still not printing. This is a kodak...
OK, first and most simple thing to try; fire up your PC in to Windows and turn on the printer. Unplug the USB cable from the back of the PC and plug it in to ANOTHER USB port. It should re-detect the printer. Once this has finished (you should get a message in the bottom right of the screen down by the clock), try a print and see what happens. Scott.
Dec 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Canon i255 printer error 5100
5100 is a carriage error. check the timing strip for contamination (plastic strip about 1/4" in width). Check for obstructions.
more information on this error can be found at http://www.fixyourownprinter.com/forums/laser/25975
Jul 12, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
KODAK 5100 AIO Printer, won't print.
I am not an expert with Kodak but you can go to their website and download all the software you need - It will do it for you. They also have a step by step solution and repair. Hope this helps you.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10/7895&pq-locale=en_US
Jan 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Sharing a Kodak 5100 All-In-One Printer
try this.............
On the computer that is connected to the printer:
  1. Open the Control Panel.
  2. Select Printers and Faxes.
  3. Right-click the KODAK All-in-One Printer, and select Properties.
  4. Select the Sharing tab.
  5. Select Share this printer.
  6. In the Share name field, type a name for your printer.
  7. Click OK.
  8. Right-click My Computer and select Properties.
  9. Select the Computer Name tab.
  10. On a piece of paper, write down the full computer name as it appears on the screen (for example: Johns Computer).
    NOTE: This is the name that you enter on the other computer(s) to access this printer.
On the other computer(s):
  1. Select Start > Run.
  2. Type two backslashes (\\) and the full computer name as it appeared on the first computer (for example: \\Johns Computer).
  3. Click OK.
    A window shows the new printer as the Shared Printer.
  4. Double-click the printer.
  5. Close all windows, then print to the Shared Printer.
Let me know if this helped.........
Dec 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
Adhesive Labels will not print
sure..may be that something from one of the papers slipped inside the machine..happens with those gummed papers at times..
http://tinyurl.com/6qcpgy
May 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Flashing red check ink lights
printer had an error that couldnt be fixed so had to replace it.
Apr 06, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare Photo Printer 500 Logo
88 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
