Question about Reliance Water Heaters
Lit pilot light, turned heater on.run for about 1 hour and pilot light went out.
  • 494 Answers
I wrote a tip on water heater lighting issues. Click on the link below to see if it can help you troubleshoot your problem.
Douglas
http://www.fixya.com/support/r4785355-trouble_shooting_common_gas_water_heater
Posted on Oct 02, 2010
A.O. Smith ProMax Plus GVR 50 101 Safety Question
You need to inspect and clean the air intake located on bottom of unit. Get more fresh air to the water heater and see if problem continues.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
Instructions for lighting the unit are located on front of water heater.
Other possible causes include: bad gas control valve, dirty combustion parts, reverse draft down the stack (caused by wind and opening door inside closed utility room), low gas pressure, air in gas line, etc.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Propane gas is heavier than air. So if you have a gas leak, then smell close to floor. Leave house immediately if you smell gas. Install a gas detector close to floor level near gas appliances.
Most water heaters today are extremely safe, because we experimented on prior generations of people, who then passed along their experience.
Aug 12, 2012 | Water Heaters
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
Pilot light has gone out how do i relight it?
Hi .. look at the control valve on the burner .,. there is a knob you can turn. It has markings for pilot and run, or something like that. turn the knob to pilot and push and hold it in. Light the pilot wit a long fireplace match. After the pilot is lit, wait about half a minute and relese the knob,, the lp[ilot should stay lit.
Apr 03, 2010 | Water Heaters
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
Water Heaters Logo
56 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
