Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
When disk is raised the center section lower by itself it is not the tractor valves because the problem stays with the disk. I have replaced one wing cylinder with a standard cross 4x8 and the other origanal I rebult is a 4x8 cessna I have also replaced one of the main frame cylinder which had been sustituted with a new part number from deere and the prblem still remains. I have onemore to change but i'm trying to determin why the problem exists
  • 333 Answers
What size disk? I take it that it is probably 20 ft or so? Because u said one of the wings. Ok so it has two cylinders that pik up the disk? On the main frame.
One of them changed. And Im sure they are hooked up right? Doe's it still drop when the lines are unplugged from the tractor? If it doe's and the cylinders are hooked up right. Then it is one or both of the cylinders bypassing around the piston. When one of them bypasses then the oil pressure between the two would eqal out on both of them because they are hooked up together.
And shut the tractor off and you should be able to hear where it is bypassing. Might need someone to listen if it goes down fast.
Posted on Oct 02, 2010
When lifting an implement on my 1060 nuffield the implement raises and lever returns to neutral but 1 minute later implement is down why is this ?
It is valve leakage or cylinder bypass leakage. If you have disconnects between the implement and the tractor raise it and then disconnect the hoses. If it stays up it is valve problems but if it still drops the cylinder piston seals are worn. After raising wiggle the valve handle to make sure it is centered. The centering springs can weaken over time or the valve can get sticky. If this doesn't help the valve may be wore out or have bad seals.
Feb 15, 2015 | Garden
A WING ON THE JD 15' MOWER WILL NOT LOWER. ANY IDEAS?
Just an idea but my guess is that it is in the hydraulic system.
Probably a safety valve that prevents it from falling in case of a hydraulic line break.
Link to JD answer center.
Answer Center from JohnDeere
Sep 09, 2014 | Garden
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
Consew 226 how to raise the walker
There's a wing nut behind the machine, loosen the wing nut and slide it lever up to adjust it higher or down for lower..
Jan 14, 2014 | Consew Sewing Machines
How do you take off the spare tire underneath?
lift the carpet and you should see a nut by the rear of the van turning it will lower the tire
Dec 29, 2010 | 1999 Dodge Caravan
Deck only raises a little bit, not the way it is supposed to. Selections 1-4 is the same level, resting on the ground. how do i fix this
The bolts or wing nuts for the deck adjustment have likely come loose or off entirely from the raising/ lowering undercarriage.
Once you have identified the loose or missing nuts (and replaced, making sure to add lock washers) then move the mower to a flat, level surface and move height lever to the lowest setting (some mowers have a flap over an ultra-low setting for this purpose).
Now tighten the nuts on the raising / lowering arms. You should now have normal control over the height. Farmerbear at FixYa.com
Sep 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Oct 11, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
23 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
