Question about HP PSC 2110 All-In-One InkJet Printer
Printer won't get off copy mode and into print mode. Will go through alighnment, etc. and print out reports. Can't print anything else.
rizla
  • 1463 Answers
SOURCE: HP1620 printer is stuck in copy mode and will not print
hi dorirn
have a look here this should help you solve it.HP Photosmart 2610 All-in-One Printer
riz.
Posted on Dec 20, 2008
yooperbud
  • 8637 Answers
SOURCE: Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 16 Answers
SOURCE: my hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Posted on Mar 01, 2009
c_robertson
  • 123 Answers
SOURCE: prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Posted on Apr 29, 2009
mace1mace
  • 1138 Answers
SOURCE: I have a Canon Pixma
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Posted on Aug 10, 2010
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
Canon mf5750 prints blank pages
Can anyone tell me where the formatter is located?
Is it part of the mainboard of the mf5750?
I read somewhere, that the formatter is responsible, if standard printing works (status reports etc), but normal printing tasks do not.
Really no solution guys? I cannot believe this.
Thanks for any advice.
Joe
May 30, 2012 | Canon LaserBase MF5750 All-In-One Printer
Blank pages when making a copy. The printer cartridge is fine. I can print demo, configuration, usage reports, etc. from the Reports menu.
Is it coming on ready mode? check scan also in same manner..open adf unit verify weather light is glowing in CCD?.. if no replace CCD..
Sep 05, 2011 | HP Laserjet M2727nf Multifunction Printer
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I just purchased a C540, color laser printer. HOWEVER, in setting the printer up, and trying to print anything, the printer won?t print. Nada. Seems as if there is no communication. Everything is plugged...
u have to installed driver first in your PC then after cheak your printer installed correctly go in control pennal open printer option see there there was showing your printer if u have installed correctly then after right click on it then set is as a default printer then try to print
Nov 15, 2009 | Computers & Internet
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
Apr 28, 2009 | Office Equipment & Supplies
Counter in MF 3110
download the service manual from HERE
(press free button and wait about 3o seconds till the download button appears)
CH 5 of the manual has details on how to enter service mode and there is a report function that should show/print the number of copies/prints etc
Please post back results so I know if I helped
Feb 15, 2008 | Canon MF3110 All-In-One Laser Printer
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
HP PSC 2110 All-In-One InkJet Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
