Question about Vacuums
This is a very new vacuum, not even 3 months old. The beater bar stopped functioning. So does the light in the switch for the bar up on the handle. Inside the lower section all looks well and new, cause it is new. All wiring and connections look fine. The motor for the bar looks fine as does the belt and pullley. I have no idea where to look for technical advise. The vacuum shops around where I live ( Howell, MI) do not want to touch a HALO vacuum cleaner. Thank you for some suggestions and your time. Regards, Hans Meulenbroek
  • hanspep Oct 02, 2010
    I would like to get some advice from someone who dealt with this very problem in this vacuum and repaired it. Thanks.
    President:
  • 1,216 Answers
There may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum
There can be 3 components at fault
1.pulley and belt system
2.Motor.
3.Switch
You yourself negate the first possibility.
a brard new machine shouls not have a motor problem.
Actually the culprit is the switch as light in the switch for the bar up on the handle is not working.try replacing this component and your machine should work , else we omly have a chance with the motor.
if you need to replace any component following manual may help.
http://www.eureka.com/service/manuals/80244.pdf
Posted on Oct 02, 2010
  • Aviral Saxena
    Aviral Saxena Oct 02, 2010
    one thing more i didn't noticed is why are you taking such a pain, if it is 3 months old it must be in guarantee period , though i have provided you the answer better call tech people and don't waste money.
  • Vacuums Master
  • 3,083 Answers
This sounds to me like a switch has failed, since you've probably checked everything for loose connections. There's also the possibility that a connector isn't "making" with a wire, or something tricky like that. I, personally, would try to get an exchange for it- it certainly shouldn't be having problems being this new, even though it has a 30 days warranty.
The following website has a lot of similar problems that you're having, and this machine really sounds like it has some serious problems:
http://www.amazon.com/Halo-3280-Ultraviolet-Upright-Cleaner/product-reviews/B000PKW170/ref=cm_cr_dp_synop?ie=UTF8&showViewpoints=0&sortBy=bySubmissionDateDescending#R2RVMEHNQC1Z5N
I would try to get my money back, even though they won't want to. Contact Oreck and see if you can get them to at least exchange it for a unit that will, hopefully, work.
Good luck, and hope this helps.
Beater bar intermently stops turning
It's likely that the belt is just slipping. Remove the bar and clean all hair, threads and other debris it collects in the bristles and around the ends. Check the belt for wear of the rubber; it may have teeth on it unless they were worn off from slipping. In that case you need a new one but save the old one for it's model number to purchase on line.
May 28, 2015 | Vacuums
I was vacuuming with my DC28 Animal and all fo a sudden the beater bar stopped working and NONE of the floor mode buttons work.. no lights or anyhting. I checked for obstructions per the Dyson manua
Check the wire connection that feeds that section. to make sure it is being supplied power. Since motor is also not working it has to be something they all have in common -POWER!
Sep 06, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Jun 19, 2017 | Bissell 6594 PowerForce Bagless Upright...
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
Windtunnel first one used 6 times beater bar stopped working, took apart cleaned and belt was fine. this one had a reset switch for beater bar. had insurance at best buy so returned for a new one. used...
Sorry, you feel like that. I have rentals and 6 windtunnel's (I prefer the bagged ones) and have never had a problem such as you have described. I think Hoover makes a great vacuum.
Sep 14, 2011 | Hoover U6630-900 WindTunnel Bagless...
I purchased a Eureka C4910 last year and have a question that I am hoping you can answer. There are two motor actions with this vacuum, 1) the vacuum suction, and 2) the beater bar. The action of the...
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
May 28, 2011 | Eureka C4910 Bagged Upright Vacuum
Why did the brushes stop rotating?
It could be a few different reasons, 1. The belt is broken, 2. The motor has died, 3. There is an obstruction, or some such thing stopping the bar from rotating (often hair and/or string) 4. The contact switch is defective. (switch that turns beater bar on when handle is tilted back) Hope this helps
Sep 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
They just stopped working!
Hoover has a 1 year warranty on their vacuums, so the newer one will be under warranty. The other won't be. It could be bad switches, even tho they sound ok, they could still be bad, One side of the cord could be open, there is also a thermostat on the motors, it may have opened up, then of course could even be the motor. Just would have to be check over.
Jan 06, 2008 | Vacuums
Brush stops
This really sounds like a belt problem. Even if it looks OK, it may have stretched. New belts are cheap, and you'll need a new one eventually - if the old one turns out to be fine, you can always keep it as a spare. A second possibility is this: Many cleaners have a control which allows you to switch off the brush/beater bar so you can clean wooden floors without damaging them (for instance, mine has a pedal-operated bar which shunts the belt between two adjacent pulleys on the brush roller, one of which is properly keyed on, and the other of which is a loose fit allowing the roller to idle. If you have something like this on your cleaner, check you have the brushes switched on, and that the mechanism is working properly. A.
Apr 13, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
