Question about GE Quiet-Aire Ductless Mini Split System Air Conditioner
What size (o.d.) drain hose do you use for a 14000 btu ,ge mini split heat pump
  • GE Master
  • 1,711 Answers
Half inch
Posted on Oct 02, 2010
Is there a video on how to install a celiera 9500 btu ductless mini split heat pump
I'm sorry but installing an air conditioner is not a DIY. Do you have line voltage for condenser? A hole drilled through the wall ~3.5"? 14-4 communication wire? Barbed fitting and nylon tubing? Refrigerant and manifold? Disconnect box? Tubing cutters with a flaring tool? HIRE A LICENSED CONTRACTOR!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 22, 2018 | Heating & Cooling
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Qshx mini split heat pump leaking
You are going to have to give a lot more information. What is leaking, how fast, etc. If it were the refrigerant you would be out by now. Where is the leak coming from.
Apr 01, 2014 | Quietside QSHX-182 18000 BTU Mini Split...
Suction line size on midea minisplit heat pump is 1/2" suppose to be 3/8" what problems will that cause?
An undersize suction line decreases the capacity, and causes the compressor to work harder and more frequent starts. It may even experience low suction pressure and high superheat.
Dec 16, 2013 | Midea 18,000 Btu 17 SEER Inverter Mini...
Why do i have to empty the water out every 2 hours 14000 btu portable plus humidifier aitconditioner 14200 btu heat pump
That is normal for a portable a/c unit if it has a drain on it you can put it on a shelf or counter and allow it to drain to a floor drain or sink. some newer units come with a pump to remove the condensate, this is the water you normaly see driping out of the a/c units in windows
Jul 21, 2011 | Soleus Heating & Cooling
GE Quiet-Aire Ductless Mini Split System Air Conditioner Logo
245 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
