Question about Briggs & Stratton Power Products 1539 Pressure Washer
I have a Generac power washer with briggs and stratten 4.5 Horse. I bought it 7 years ago and stored it. I started for the first time today, it started on the first pull and runs great, but doesn't pump syphon cleaning solution from a mixture in bucket. Why not?
  • 760 Answers
I hope you did have it connected to a water line. I'm also assuming the pressure washer function is working ok. Some times the sypon tubing gets clogged from cleaners drying up and building up in tubing and passageway. Does your gun have a cleaning on/off function sometimes by twisting handle? If you have an extra hose, try forcing some water in the tubing while trying to apply solution. If all else fails, clean all solution passageways.
Posted on Oct 02, 2010
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Generac mc-35 wont start no spark at plug
make sure magneto is VERY close to the flywheel. Like, two pieces of paper close.
Mar 26, 2014 | Generac Electrical Supplies
My Troy built 2700 power washer won't start. it's been 8-10 months since I used it last. I bought it 2 years ago.
99% of the time is the fuel that has unstabled in your carburetor you can try to clean it but replacing would be recommended.
Aug 05, 2013 | Briggs Stratton 198347gs Pump Assembly Kit...
Hi i have a briggs and stratton pressure washer cv 2300psi omb 6.75 horse power 2.0 gpm .It was working about amonth ago and jus stop.I pull the string a couple of times and nothing,so i left it .Can you...
hi marlo. check the fuel level, the air filter, and the spark plug. clean or replace as necessary. then get a can of starter fluid and an assistant. give the air intake area, by the air filter a couple of squirts of starter fluid and then start it up. keep it running by squirting more starter fluid for up to 2 minutes until it will run on it's own. J.
Jul 15, 2011 | Briggs & Stratton Gas Pressure Washer...
John Deere LA125 riding mower, three years old, 84 hours, Briggs 21 hp engine. I mowed the lawn. I cleaned the machine with a water hose. Now, IF it starts it will die after about 10 seconds. I took the...
Bought a new John Deere LA125 IN 08 only has 106 hrs on it, maintained it to a tee, changed oil etc, now it smokes, blue smoke, smells like burning oil, it does this when i rev up or down or when theres a load on the engine, but doesnt smoke all the time, i chaanged my plug which was amazing it would start it has the 21 horse briggs and stratten engine. Any help appreciated.
May 09, 2011 | Garden
I have a Craftsman (B & S) pressure washer 7 HP 2900 psi 2.3 GPM Model No. 580.752410. It's about 4 yrs old and 2 years ago I put a seal kit 193807GS into it after it failed to put out proper pressure....
I worked at a tool rental store while attending college and discovered how to extend the life of tools. Really a simple trick that you practice every day. Although your car can travel at a very high rate of speed, you only use about 30 to 40 percent of its power, if however you traveled at 100 mph everywhere that you needed to go, you would greatly shorten its life. Althouth I do believe that you have received good service from your unit, you may have increased the life by using only 60 to 80 percent of its pressure potential for most general work and increase only for stubborn debris.
Apr 26, 2011 | Briggs & Stratton Garden
I own a Generac power washer model 01292=1 type 6670CP GPM2.9 PSI 2300 and request the owners manuel for this model Thank You Al Bonfardino albonfardino@yahoo.com
Go to the Briggs and Stratton website and go to their generators then to Generac. You should be able to track down a link to putting in your model number. (4) PDF manuals show for that model. http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm?rd=1
Apr 30, 2010 | Briggs Garden
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Briggs & Stratton Power Products 1539 Pressure Washer  Logo
200 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
