Question about Radio Shack Pro-94 Scanner
How do i reset my pro 94 to factory specs - Radio Shack Pro-94 Scanner
    President:
  • 2,761 Answers
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, turn the scanner ON.
CLEAR flashes for about 5 seconds as the scanner resets. DO NOT turn the scanner OFF until CLEAR stops flashing,
Need the manual for your scanner? You can download and print it, free of charge, here:
http://support.radioshack.com/support_electronics/doc61/61172.pdf
Bill B
Listening in since the 60's
Posted on Oct 02, 2010
How do i work a pro-94 radioshack police scanner?
https://www.manualslib.com/manual/137757/Radio-Shack-Pro-94.html
Specs are not needed. I suspect you need the local frequencies and how to program them. The scanner CAN be set to scan for the local frequencies. Have a pad and paper ready and write down the ones you want to keep.
You must obtain the local frequencies, try Google. They are public knowledge, but hard to find. Local Hams or a Radio Shack will likely have the frequencies. Be nice, be polite, no one has to give you this information.
Jan 29, 2018 | Radio Communications
I have a klh 116615p bg11 12 sub and need to know the watagew it doesnt say
This woofer was taken from a KLH Pro-71 Series. These were the top of the KLH line from ~94-99 when it was still a real company and not just a name. The woofer is rated for 5-350 watts at 8 ohms. Source: KLH Pro Series-71 Spec Sheet.
Apr 06, 2011 | KLH Audio Players & Recorders
My pro 94 scanner shows the code luired when turned on. How do I fix this?
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
Bill B.
Oct 27, 2010 | Radio Shack Pro-94 Scanner
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
How to clear all my frequencies from my portable scanner
To clear all information that you've programmed into the scanner you can perform a RESET to original factory settings:
1. Turn off the scanner.
2. While holding down the 2 and 9 keys, turn on the
scanner. CLEAR flashes for about 5 seconds as
the scanner clears its memory.
Note: Do not turn off the scanner again until CLEAR
stops flashing. Otherwise, the scanner might not clear its memory properly.
Bill B
Apr 03, 2010 | Radio Shack Pro-94 Scanner
I have a radio shack pro 94 scanner that gets stuck in the high channels. How can I make it scan to other channels
Getting "stuck" indicates that the scanner may need to be reset to restore proper operation. This is a fairly drastic step that will erase ALL information that you've programmed into the scanner, but it's about the only fix. To reset the PRO-94:
- Turn the scanner OFF
- While holding down the 2 and 9 keys, power the scanner ON.
- CLEAR will flash for about 5 seconds as the scanners clears its memory and restores factory settings. Do not turn the scanner OFF or press any keys until the CLEAR message stops flashing.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
Bill B
Mar 05, 2010 | Radio Shack Pro-96 Scanner
Radio Shack Pro-94
No telling what he did, but if you've tried deleting his entries and the scanner is still locked up, you'll need to reset it. This procedure will clear all the information you have have stored in the scanner.
2. While holding down the 2 and 9 keys, turn the scanner ON. CLEAR will flash for about 5 seconds while the scanner clears its memory.
NOTE: Do not turn the scanner OFF until CLEAR stops flashing.
Need the operating manual for your scanner? You can download;/print it here:
Bill B
Feb 17, 2010 | Radio Shack Pro-94 Scanner
Scanner says WIRED when i turn it on, and it won't do anything
A RESET may clear the problem, but it will also erase all frequencies and data that you've programmed into the scanner. To RESET the PRO-94,
- While holding the 2 and 9 keys down, turn the scanner ON. CLEAR will flash for about 5 seconds as the scanner clears its memory and restores factory settings. Do NOT turn the scanner OFF until CLEAR stops flashing.
Bill B
Jan 22, 2010 | Radio Shack Pro-94 Scanner
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How to reset to factory specs??
Enter the SETUP menu and select RESET. You'll be prompted to reset two sections. Answer YES to both and everything that can be set to default will go back to the factory default state.
Jan 13, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Radio Shack Pro-94 Scanner Logo
1,483 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
