Question about Zhone (6218-I2-200) Router
Username & password
Attn: tech curly,
How do i change my username & password from "admin". on my Zhone 6218-I2. Will it affect my WPA settings.
I had previously followed your advice Re: unsecure to secure wifi connection on my Dell inspiron 6000. It worked out great.
Can I also use Mac filtering. How does one do that? Or is it possible to change my SSID from Wireless to any other name.
Please advise.
Thanks, again in advance.
  • andymg Aug 04, 2008
    I have Speedtouch router and trying to make the connection secured by typing the IP address. but everytime i log on it ask me to put my user name and password which i did not done yet since i install it. I try to put admin but its doesnt work. and the internet connetion is okay but limited only. please any one can give me an advice on wht to do with it.
    jeddahboy
  • 298 Answers
Changing the router password from admin to any password I think that you would be possible. Other brands of router has that option. And the router password won't affect the password for the wireless connection, they are different from each other. Wireless mac Filter is another way of securing your wireless network. Its done by listing the MAC Addrses (media Access control) or the physical address of your wireless adapter on your computer/s to either allow them to connect to the network or not to connect to the network. but I recommend to just use WPA security. It's secured and its much easier to add another wireless device to your network, because you just need to put the password and no need to get the MAC address and manually encode in on your router setup page. Its also possible to change the SSID or the name of your network.
I will get back to you with the steps on how to change the ssid adn change the router password. Okay?
Posted on May 26, 2008
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 26, 2008
    *I suggest that you do this on a computer that has a wired connection to the router if possible.
    To change the ssid
    1. log back in to the setup page of your router (if you cant remember how to do that just check the steps that I sent you before)
    2. click wireless and select basic (this in on the left hand side of your router page)
    3. middle of the page look for SSID (its Wireless by default) you can delete wireless and type any name that you want, then click on save/apply at the bottom.
    After the router save the settings your wireless laptop will get disconnected from the wireless connection all you need to do it reconnect and check if you will see
    the name that you assigned to your router.
    1. One you are in the router setu page on the left handside of the screen click on Management
    2. Under management there will be a Folder Named Access Control, click on it.
    3. Select on Password, the screen that you will have you will see username, old password, new password and confirm password. This is where you can change the router password.
    4. for the username field click the drop down arrow and select admin, for the old password field type "admin" and for the new password field type the new password that you want for your router.
    then retype the new password on the confirm password field. then click save/apply. and you can log backin using admin for username and password is the new password that you have set.
    I hope this one helps.
2 Suggested Answers
rahul26485
  • 611 Answers
SOURCE: Username & password
yes you can change the ssid
do to device then select adminstrator then change it username and password
Posted on Aug 12, 2008
Need login and password for a Zhone 6519
admin=username
cciadmin=password
for advanced users
Jul 30, 2012 | Zhone (6218-I2-200) Router
Zhone 6212-I3-200-0PA, What is the default username and password for this router?
its usually default:
admin
admin
or
admin
pass
or
admin
(no password)
try them and let me knw how you get on?
Mar 08, 2011 | Zhone 6212-I3-200 Router
I need to change my Nat and for that i need to log in, in my zhones IP adrees but i dont know the username and password what can i do?
If you don't know the password, all you need to do is reset your router, then it will be all factory defaults again.
The default user name is Admin and the password is Admin.
Dec 22, 2010 | Zhone (6218-I2-200) Router
How do I find my password
192.168.1.1
Wireless settings.
Default username: user OR username OR admin
Default password: password
Feb 27, 2010 | Zhone (6218-I2-200) Router
Need login and password for a Zhone router/modem Model #:6218-I2-200-0CC.
If you got your Zhone modem from consolidated communications then the login is admin pass is cciadmin
Dec 20, 2009 | Zhone (6218-I2-200) Router
What is the Username and password for model:6218-I2-200-0CC
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
IF you still not able then press RESET button it is in back side of router press it for 10 seconds then follow the above instruction .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 10, 2009 | Zhone (6218-I2-200) Router
I can't log in my router to config it for portforwarding.. I have my ip address but the username and the password it doesn't work.. I have tried with username: admin & password:1234 and usern:admin and...
its not actually a problem, all u have to do is to manually restart ur router and try again with the user name admin and with the password 123456 or 1234. hope it solves ur problem.
Apr 07, 2009 | Zhone (6218-I2-200) Router
Username & password
Jul 15, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Unsecure to Secure Wi-Fi Connection
Hi!
You can try this.
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and click on
Enter.
A login screen like the one below will be displayed after you connect to the
user interface.
3. Enter your user name and password, and then click on OK to display
the user interface. You type admin for both username and password field.
4. Click the + sign next to Wireless
5. Click on Security - Now go on the network authentication set it to WPA-PSK
6. You will have a field where you can type your password - make sure its at least 8-63 characters
7. Then you click appy/save. Then you reconnect to your wireless network and this time you will be ask for a password.
In case you will still have a problem just reply to this post.
May 22, 2008 | Zhone (6218-I2-200) Router
Zhone (6218-I2-200) Router Logo
930 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
