Question about U-Line Icemaker
U-Line Echelon Model B12115
The ice maker is not making ice. The water is still running. I am not at the location of the ice maker. It is our beach house in Santa Rosa Beach Florida
    Problem Solver:
  • 11 Answers
Whne you are on site, call 1-800-779-2547 for help. This is U-Line's tech support line,
http://www.u-lineservice.com
Posted on Dec 23, 2008
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Tip
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
U-line UC02175 water inside pooling under veg drawer, icemaker supply turned off, no water in catch pan inside back
Well sounds like your ice maker evaporator drain hole is frozen, every time the unit goes into defrost cycle, water backs up and leaks down to the drawer. You can try turn off the refer for 48hrs with the doors open, most case it will reset by it self. If it is happening again in few weeks, then you evaporator drain pan heater is not working. Also make sure the doors are shut all the time.
Feb 03, 2010 | U-Line CO2075F-B Echelon Refrigerator Ice...
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
Jul 29, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Leak out of the from of the ice machine - flashing p1
P1 means a problem with your drain. Most of the time its a kink in the line. Double check your drain line or it could even be a bad drain pump.
Mar 18, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
U-line model ulr-60b
hi,
periodical clean can smooth the operation of your ice maker.
at this link you can have the ice maker cleaning guidelines:
http://lib.store.yahoo.net/lib/usappliance/echelon-icemaker-manual.pdf
Sep 09, 2008 | U-Line Refrigerator Ice Maker
U-Line Icemaker Logo
591 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
