Question about Refrigerators
I have a Kenmore Chest Freezer model 253.14772100 sometimes when the lid closes the freezer display goes to OFF and the freezer shuts off. When you adjust the temp it waits a minute then starts clicking back up one degree at a time and other times shuts off. The dig display wors off and on. What is my problem?
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 363 Answers
SOURCE: LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Posted on Jul 30, 2009
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
