Question about Dishwashers
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 02, 2010
My Kenmore ultra wash dishwasher does not drain all the time. I am now stuck with water in the bottom and has gone through the whole cycle.
The MOST SIMPLE, first thing to check is the drain hose. disconnect it at both ends and BLAST water through it to clean it out... or replace it if it looks questionable...
Mar 03, 2016 | Kenmore Dishwashers
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
Kenmore Elite Dishwasher doesn't pump all the water out at the end of cycle
How much water? Does some drain out. If so its usually a dirty filter. Some Dishwashers have several filters underneath the bottom sprayer. Here is a link that may help http://www.managemylife.com/mmh/articles/authored/video-when-to-clean-a-removable-dishwasher-filter Also this link put in your model number and view how to clean your specific dishwasher. Hope this helps.
Sep 14, 2012 | Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water isn't flowing in through the spinners in the dishwasher.
Look at the end of the wash and no water in the bottom, it is OK. The water is pumped out through the pump. Hence you would have found the water mid way. Pump will start after the wash cycle is fully finished it's function or as per the float level!
May 31, 2010 | Viking 24 in. Professional Series VUD141...
Kenmore 655 Ultra Wash- dishes not getting clean and have a residue on them when done washing. Arms appear to swing freely.
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Sep 01, 2009 | Kenmore Dishwashers
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
209 people viewed this question
Top Dishwashers Experts
