Question about Xerox DocuColor 12 Printer
XEROX DOCUCOLOR 12
The top half of the page prints okay, but bottom half the color are faded.
I called in the xerox technician, but she could not identify the problem.
She kept saying, it could be the Drum unit or IBT or Fuser or......something else.
I declined her assistance, but now i am stuck with a non working printer?
Any help will be greatly appreciated.
Thanks
Nathan
If you are doing color copies and missing more than 1 color or if 1st copy is fine 2nd is not. It most likely retract clutch for cleaner to IBT belt. If all colors there and half copy than can be 2 Btr retract clutch. Also check silver patch on inbroad end of IBT belt for dirt caused by bad drum. Also check for bad bearing on front left side of Ibt frame.
Posted on Jan 29, 2009
    Problem Solver:
If you open the front door of the DC1250 and pull out the conveyor unit, you will see the heater unit on your right hand side. We need you to remove the heater cover (fastened by two screws). Once the heater cover is opened, you will see a black long strip on your left hand side whereby you will notice oil on it. Next you remove the fuser web (on the right hand underside of the heater unit) whereby it will reveal the Upper heater roller and Lower pressure roller. Please check if you see any oil stains on the Upper fuser roller. If there is, it means the oil pump, oil pipe etc are working well (i.e oil is supplied to the Upper roller).
Next we need you to check if there are any scratch marks on the Upper Heater Roller. We need you to recall if you have had encounter or incidences of paper jam at the heater unit whereby you pulled out the paper to clear the jam. We are concerned that the upper roller may be scratched. From the print out results, there is a fusing problem with the copier, which could be a result of the fuser nip clutch and also the upper fuser roller.
Posted on Aug 21, 2008
Remove drum unit. check charge wire for contamination. clean or replace. Visually check fuser for an even glossy appearance. If it looks dry or damaged in any way a service is needed. IBT is a bit more difficult to check. If you have the know how to remove it. You should see a very shiny surface free from contamination of toner or paper dust, ect. clean if necessary and replace. If contamination reoccurs suspect cleaner. Last is the BTR check for proper operation and clean, repair or adjust if necessary.
Posted on Jun 12, 2008
Faded line going across my print
Hi Good day!! i would like to help with your problem regarding in your unit, i think the problem of this is the toner, maybe the toner is damage that may cause print to faded, try to use a spare or a new toner. and then try to print a test page.
Apr 11, 2012 | Xerox DocuColor 12 Printer
Xerox dc12 printer
You will need a technician to replace a clutch.
May 18, 2010 | Xerox DocuColor 12 Printer
Docucolor 12 low density
cambia reveladores y reza un padrenuestro
Oct 31, 2009 | Xerox DocuColor 12 Color Copier
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 2045 print White areas
a number of reasons can cause this. have you tried each colour individually? after this swap drums and see if fault moves with the drum. otherwise its probably developer
Jan 21, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
DC12 - Yellow Banding (top to bottom)
There is a software patch on the Xerox.com site.
Once there click Support and Drivers.
Once there in the search box enter dc 12
Once to the Support area. Type in Yellow in the search box. That should direct you to the patches.
I hope this helps.
Dec 30, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
513 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
