Question about Sylvania LC420SS8 LCD TV
My remote is not working on the TV. The remote is fine because we have to sylvania TV's and that remote works for the other tv. So it has to do with the television.
  • 11,361 Answers
Can you use the buttons on the TV? If you can then it can be the remote IR receiver module inside. Check to see if it has remote sensor input jack on the back, if it does, it can be dirty contact in side the jack, you can clen it by plug and unplug the jack with the small headphone plug a couple of time to clean the switch contacts. If it does not have one you can try new remote IR receiver module. You can also check to see if the module is getting the 5v feeding it.
Check www.shopjimmy.com
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 02, 2010
4 Suggested Answers
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
Posted on Oct 29, 2008
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
Sylvania TV Remote Control System Is In Operative
If your new Sylvania remote is functionally identical to the old one and does not work, make sure nothing is blocking the path between the remote and your TV and try again. If no results, the IR detector in the TV may have failed
Jun 28, 2013 | Sylvania SRT2319 TV
Accessing input (source) codes on Sylvania TV
NO. As there is no Menu button on the front panel of this tV, you must have a remote control to do input selections.
Jun 08, 2012 | Sylvania Televison & Video
REMOTE DOES NOT WORK ON SYLVANIA TV
well, i got a one for all remote from a wal mart or some where else, and i have a sylvania tv. it works for my tv. might want to look into that. www.oneforall.com
May 27, 2009 | Sylvania Televison & Video
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
27" sylvania tv stuck on one channel
unplug tv for about half a hour and replug it back in to reset it and see if that works..I also have that big remote and it worked find for me the first time so maybe tv just needs to be reset. hope that helps
Apr 05, 2009 | Televison & Video
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Unable to turn on video mode without remote. I dont have remote
Who the hell builds a TV w/o a AUX or video button on the TV.... i hate this darn sylvania...
Jan 10, 2008 | Sylvania 6419TC 19" TV
Sylvania TV
i had a sylvania tv and i accidentaly cracked my remote... i got this remote and it will work for a little wile then it will stop working for a wile, then it will work and now its been a wile and i forgot the code for this tv.... i only wantthe code but i cant find were to get it... i will try codes from other sites but they dont work
Dec 27, 2007 | Televison & Video
Sylvania LC420SS8 LCD TV Logo
70 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
