Question about Fisher and Paykel GWL10 Dryer
I have a Fisher and Paykel AD55 dryer. When I turn it on it make a noise but the drum doesn't turn around
  • mcawood670 Oct 02, 2010
    That is the complete model number on the front of the machine. I can't get to the back of the machine as it is too heavy for me to move. The only other wording it has is "dualcare". It is a very basic model and the only cycle choice is a manual dualcare 'hot ' or "cool" setting.
    President:
  • 2,468 Answers
If it tries to start when you push the start button and quits when you release it,the belt is broken,theres a belt sensing switch by the motor so when the belt breaks the unit wont stay running
Posted on Oct 02, 2010
  • 347 Answers
This model number is not complete. need to have exact number for a more accurate diagnosis
Fisher paykel dryer ad55 making loud screaching noise
sounds like your berinfg has worn out neds to be pulled upart to replace it
Jul 15, 2014 | Fisher and Paykel Dryers
Why does Drum does not rotate
can be severl causes check drum rotates by hand freely is good most common fault is the capacity needs replacing
Jun 08, 2014 | Fisher and Paykel Dryers
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Old fisher and paykel dryer AD55 doesnt always heat up.
there's a heat senor on the back of the drum(I think) most of the older model dryers have them check to see if it's bad
Mar 31, 2011 | Fisher and Paykel DEGX1 Electric Dryer
How do I replace the main bearing in an AD55 Fisher & Paykel dryer? How difficult is it to get at?
not that hard you take the back of then take the barrel out punch out the 56833 strem grease bearing then replace with new one and re assemble just note the way the driver belt comes of there tricky to put back on
let me know how you went
Dec 31, 2010 | Fisher and Paykel Dryers
F&P AD55 manual dryer - With very light load motor make noise but will not turn. If I open door to spin drum and quickly close door it sometimes will start turning. Help!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 21, 2010 | Fisher and Paykel Dryers
I have a AD55 Dryer. When I turn it on it makes a sound but the dryer doesn't turn around.
Does the sound it makes sound like a motor running? When you start a dryer a motor that is coupled to the drum starts turning. It is possible that the belt has come off of the motor pulley. You will need to remove the back cover and look inside to determine if this has happened.
Oct 02, 2010 | Fisher and Paykel Dryers
AD55 Dryer makes a dual clunk like it is out of round.
Run the dryer and look through the front door and watch for if the drum is running out of round at the back. The AD55 only has one bearing and this is at the rear of the drum, the front of the drum is supported by 6 plastic tabs that it glides over. These tabs are reversible if they become worn and a drum bearing assembly kit is available from Fisher & Paykel. For a detailed drawing of the dryer contact your Fisher & Paykel service center and they will email you a copy.
Mar 02, 2010 | Fisher and Paykel Dryers
Squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
May 24, 2009 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
249 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
